you can ignore this warning, and stream on other system by vlc by providing IP of the system where you running deepstream app, you can get the string when run deepstream app, rtsp://localhost:8554/ds-test ***
You should be able to view the tiled output at the same rtsp url when running a multistream pipeline. If you are looking for a separate rtsp url for each input stream, then that is not currently supported in deepstream-app.
This is already supported AFAIK, if you provide another
[sink1]
enable=1 #Type - 1=FakeSink 2=EglSink 3=File
type=4
codec=1
sync=0
source-id=1
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5401
rtsp-port=8555
[source1]
enable=1
type=4
url=rtsp://:port/part
it will start two rtsp server at port 8554 and 8555 for source0 and source1
I have tested it with 5 sources/sinks and it works just fine
I pushed two RTSP streams out, one 8554 and one 8555, but there will be a freeze when receiving and displaying on another monitor. Have you encountered this problem?
deepstream-app:25327): GLib-GObject-WARNING **: 00:18:53.504: g_object_get_is_valid_property: object class 'GstUDPSrc' has no property named 'pt'
I tried accessing it from another laptop using vlc which is connected to same wifi router as my tx2.
I used link: rtsp://localhost:8555/ds-test directly in vlc .
Each time when i try to connect, this new error message shows up in jetson tx2 terminal !!!
