Hi NVIDIA team,
I am getting the video stream from camera and I am running the detection algorithm on the incoming frames.Once the inference is done,I have to stream these frames with h.264 encoding to another system.How can I proceed?
Hi NVIDIA team,
Please check the documentation here NVIDIA DeepStream SDK Developer Guide — DeepStream 6.1.1 Release documentation
You’ll find an explanation of the config groups for deepstream-app.
Here’s an example for re-streaming as rtsp (h264 codec):
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=4
codec=1
sync=0
source-id=0
gpu-id=0
bitrate=4000000
nvbuf-memory-type=0
udp-port=5400
rtsp-port=8554
To see how its done in your own code you can check the code of deepstream-app.
