Running the above results in the following on the server:
Invalid MIT-MAGIC-COOKIE-1 keynvbuf_utils: Could not get EGL display connection
Invalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyInvalid MIT-MAGIC-COOKIE-1 keyOpening in BLOCKING MODE
The client has the following output:
gst-launch-1.0 rtspsrc -v location=rtsp://192.168.1.184:8554/test ! application/x-rtp, media=video, encoding-name=H265 ! rtph265depay ! decodebin ! xvimagesink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Progress: (open) Opening Stream
Pipeline is PREROLLED …
Prerolled, waiting for progress to finish…
Progress: (connect) Connecting to rtsp://192.168.1.184:8554/test
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Unhandled error
Additional debug info:
…/gst-plugins-good/gst/rtsp/gstrtspsrc.c(6696): gst_rtspsrc_send (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
Service Unavailable (503)
ERROR: pipeline doesn’t want to preroll.
Setting pipeline to NULL …
Freeing pipeline …
EDIT 1: When the display is set to :1 (which it defaults to when I have a screen plugged in) I get the following output on the server:
NvMMLiteOpen : Block : BlockType = 8
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
NVMEDIA: H265 : Profile : 1
NVMEDIA_ENC: bBlitMode is set to TRUE
and the client:
Progress: (request) SETUP stream 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: latency = 2000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-sync = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: rfc7273-sync = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-time-source = ntp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: drop-on-latency = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: max-rtcp-rtp-time-diff = 1000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: max-ts-offset-adjustment = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: buffer-mode = slave
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 5000000000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: caps = application/x-rtcp
Progress: (open) Opened Stream
Setting pipeline to PLAYING …
New clock: GstSystemClock
Progress: (request) Sending PLAY request
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
Progress: (request) Sent PLAY request
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1.GstPad:src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0.GstProxyPad:proxypad1: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:sync_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:rtcp_sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtcp_sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpStorage:rtpstorage0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpStorage:rtpstorage0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 0
Redistribute latency…
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: latency = 2000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: drop-on-latency = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: do-lost = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: mode = slave
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: do-retransmission = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: max-rtcp-rtp-time-diff = 1000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: max-dropout-time = 60000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: max-misorder-time = 2000
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: rfc7273-sync = false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0: max-ts-offset-adjustment = 0
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpPtDemux:rtpptdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1: caps = application/x-rtp, media=(string)video, encoding-name=(string)H265
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRtpH265Depay:rtph265depay0.GstPad:src: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101014000000300000300f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101014000000300000300f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101014000000300000300f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH265Parse:h265parse0.GstPad:src: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01014000000000000000000078f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90, width=(int)1920, height=(int)1080, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/avdec_h265:avdec_h265-0.GstPad:sink: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01014000000000000000000078f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90, width=(int)1920, height=(int)1080, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01014000000000000000000078f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90, width=(int)1920, height=(int)1080, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01014000000000000000000078f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90, width=(int)1920, height=(int)1080, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH265Parse:h265parse0.GstPad:sink: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101014000000300000300f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:sink: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101014000000300000300f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstGhostPad:sink: caps = video/x-h265, stream-format=(string)hvc1, alignment=(string)au, codec_data=(buffer)01420101014000000300000300f000fcfdf8f800000f03200001001840010c01ffff01400000030000030000030000030078ac09210001002142010101400000030000030000030000030078a003c0801107cb96b7908444b82022000100074401c073c0cc90
/GstPipeline:pipeline0/GstRtpH265Depay:rtph265depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_3102690005_96.GstProxyPad:proxypad5: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_3102690005_96.GstProxyPad:proxypad4: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)QgEBAUAAAAMAAAMAAAMAAAMAeKADwIARB8uWt5CERLgg, sprop-pps=(string)“RAHAc8DMkA==”, a-tool=(string)GStreamer, a-type=(string)broadcast, a-framerate=(string)25, a-ts-refclk=(string)local, a-mediaclk=(string)sender, ssrc=(uint)3102690005, clock-base=(uint)3499200527, seqnum-base=(uint)20792, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1, onvif-mode=(boolean)false
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< “application/x-rtp-source-stats,\ ssrc=(uint)3102690005,\ internal=(boolean)false,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)true,\ seqnum-base=(int)-1,\ clock-rate=(int)90000,\ rtp-from=(string)192.168.1.184:33478,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)817365,\ packets-received=(guint64)614,\ bytes-received=(guint64)841925,\ bitrate=(guint64)3307743,\ packets-lost=(int)-1,\ jitter=(uint)149,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ recv-packet-rate=(uint)3911,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0,\ sent-rb=(boolean)true,\ sent-rb-fractionlost=(uint)0,\ sent-rb-packetslost=(int)-1,\ sent-rb-exthighestseq=(uint)21406,\ sent-rb-jitter=(uint)149,\ sent-rb-lsr=(uint)0,\ sent-rb-dlsr=(uint)0,\ have-rb=(boolean)false,\ rb-fractionlost=(uint)0,\ rb-packetslost=(int)0,\ rb-exthighestseq=(uint)0,\ rb-jitter=(uint)0,\ rb-lsr=(uint)0,\ rb-dlsr=(uint)0,\ rb-round-trip=(uint)0;”, “application/x-rtp-source-stats,\ ssrc=(uint)947265870,\ internal=(boolean)true,\ validated=(boolean)true,\ received-bye=(boolean)false,\ is-csrc=(boolean)false,\ is-sender=(boolean)false,\ seqnum-base=(int)-1,\ clock-rate=(int)-1,\ octets-sent=(guint64)0,\ packets-sent=(guint64)0,\ octets-received=(guint64)0,\ packets-received=(guint64)0,\ bytes-received=(guint64)0,\ bitrate=(guint64)0,\ packets-lost=(int)0,\ jitter=(uint)0,\ sent-pli-count=(uint)0,\ recv-pli-count=(uint)0,\ sent-fir-count=(uint)0,\ recv-fir-count=(uint)0,\ sent-nack-count=(uint)0,\ recv-nack-count=(uint)0,\ recv-packet-rate=(uint)0,\ have-sr=(boolean)false,\ sr-ntptime=(guint64)0,\ sr-rtptime=(uint)0,\ sr-octet-count=(uint)0,\ sr-packet-count=(uint)0;” >, rtx-count=(uint)0, recv-rtx-req-count=(uint)0, sent-rtx-req-count=(uint)0;
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSink:udpsink1.GstPad:sink: caps = application/x-rtcp
/GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0.GstProxyPad:proxypad3: caps = application/x-rtcp
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/avdec_h265:avdec_h265-0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)1920, height=(int)1080, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:0:0:0, framerate=(fraction)25/1
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: Internal data stream error.
…/gstreamer/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:02.077542856
Freeing pipeline …
EDIT2: The stream can be played through VLC like this. Why won’t the gstreamer client pick it up?
