Hi everyone,
I am running the following command currently to stream 3 MJPEG cameras side-by-side on one combined stream over tcp with the Jetson Orin Nano:
gst-launch-1.0 -vvv nvcompositor name=comp \
sink_0::xpos=0 sink_0::ypos=0 sink_0::width=640 sink_0::height=480 \
sink_1::xpos=640 sink_1::ypos=0 sink_1::width=640 sink_1::height=480 \
sink_2::xpos=1280 sink_2::ypos=0 sink_2::width=640 sink_1::height=480 ! \
nvvidconv ! 'video/x-raw,width=1920,height=480,framerate=30/1,format=NV12' ! x264enc bitrate=1000 ! mpegtsmux ! tcpserversink host=0.0.0.0 port=5001 -e \
v4l2src device=/dev/video0 ! image/jpeg,format=MJPG, width=640, height=480, framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! comp.sink_0 \
v4l2src device=/dev/video2 ! image/jpeg,format=MJPG, width=640, height=480, framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! comp.sink_1 \
v4l2src device=/dev/video4 ! image/jpeg,format=MJPG, width=640, height=480, framerate=30/1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! comp.sink_2
This accomplishes what I want, but the h264 encoding uses a lot of cpu resources. I just want to combine the 3 mjpeg streams together into one stream side by side without the h264 encoding. I feel I do not need to do the h264 encoding step, but I could not find another command to do so. If someone could point me in the correct direction for the correct gstreamer command to do this, that would be appreciated.
Thanks,
Devin
