I am setting this topic as i am facing an issue that my poor gstreammer capabilities are not able to deal with. Briefly, I have make an application that fetch a webcam frame, detect some objects and put some additional information on this frame and need stream it through network. All this processing and fetching is done through opencv.finally i have opencv Mat image that needs to be send it over network. The actual issue is it needs to be live streaming with minimum latency? It can be either UDP /RTSP??
How could i achieve this ? Can able provide any sample/example application that streams out opencv image over network?
Regards,
Satheesh Ramasamy
