• DeepStream Version
• TensorRT Version
I am getting the following error:
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source_bin 1
Creating Tee
Creating nvstreamdemux
Creating the pgie
Creating gst-dsmetamux
Creating tiler
Creating nvvidconv
Creating nvosd
Creating Code Parser
Creating Container
Creating FILESINK
WARNING: Overriding infer-config batch-size 1 with number of sources 2
Adding elements to Pipeline
0:00:00.050682174 367 0x2605f00 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.050702684 367 0x2605f00 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat YM12
0:00:00.050707286 367 0x2605f00 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.050711117 367 0x2605f00 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat YM12
0:00:00.050719570 367 0x2605f00 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x25e5a80 Failed to determine interlace mode
0:00:00.050729670 367 0x2605f00 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.050734122 367 0x2605f00 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe minimum capture size for pixelformat NM12
0:00:00.050739142 367 0x2605f00 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:encoder:sink Unable to try format: Unknown error -1
0:00:00.050744929 367 0x2605f00 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:encoder:sink Could not probe maximum capture size for pixelformat NM12
0:00:00.050750625 367 0x2605f00 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x25e5a80 Failed to determine interlace mode
0:00:00.050773864 367 0x2605f00 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:encoder:src Unable to try format: Unknown error -1
0:00:00.050779780 367 0x2605f00 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:encoder:src Could not probe minimum capture size for pixelformat H265
0:00:00.050782944 367 0x2605f00 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:encoder:src Unable to try format: Unknown error -1
0:00:00.050786354 367 0x2605f00 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:encoder:src Could not probe maximum capture size for pixelformat H265
0:00:00.050917437 367 0x2605f00 WARN nvstreammux gstnvstreammux.c:2809:gst_nvstreammux_change_state: error: Output width not set
Error: gst-library-error-quark: Output width not set (5): gstnvstreammux.c(2809): gst_nvstreammux_change_state (): /GstPipeline:pipeline1/GstNvStreamMux:Stream-muxervehiclecount
