Streammux set property
• DeepStream Version
• TensorRT Version
Hi how do I set streammux.set_property(“config-file-path”,“source0.yaml”) ?
is this even possible?
C/C++:
g_object_set (G_OBJECT (streammux), "config-file-path", “source0.yaml”, NULL);
python:
streammux.set_property('config-file-path', 'source0.yaml')
I am getting the following error…
TypeError: object of type GstNvStreamMux' does not have property config-file-path’
This is my program…
I am trying to implement the parallel model inferencing on deepstream…
parallel.py (15.6 KB)
Let me know where am I going wrong??
Why do you create nvstreammux twice?It may be difficult to convert this whole project to python. Could you tell us the reason why you need to change it to python?
Because I am using python language, and all my other files are in python!
OK. It’s difficult to convert this whole project to python. You need to add many bindings in the project by yourself. You can refer to the link below:https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/master/bindings
