I recently switched from 32 bit Ubuntu 9.04 to 64 bit Ubuntu 9.04.
I am using 180.44 NVIDIA driver that comes with the unrestricted drivers released by Ubuntu
I have installed 2.2 Cuda, since I could not get 2.3 to run with the 180.44 driver, and newer drivers would not work correctly (always would go into low graphics mode or hang X-windows.
Everything compiles successfully in the SDK,
the output of deviceQuery is:
CUDA Device Query (Runtime API) version (CUDART static linking)
There are 2 devices supporting CUDA
Device 0: "GeForce 8700M GT"
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 267714560 bytes
Number of multiprocessors: 4
Number of cores: 32
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.25 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: Yes
Support host page-locked memory mapping: Yes
Compute mode: Default (multiple host threads can use this device simultaneously)
Device 1: "GeForce 8700M GT"
Total amount of global memory: 268173312 bytes
Number of cores: 32
Warp size: 32
Run time limit on kernels: No
Integrated: Yes
Test PASSED
Press ENTER to exit
if I run simpleStreams I get:
running on: GeForce 8700M GT
cudaSafeCall() Runtime API error in file <simpleStreams.cu>, line 132 : feature is not yet implement
I never got this error running 2.2 Cuda on the 32 bit version. Any suggestions??
