I am implementing a delay sum beamformer with cuda, I am having a large performance hit when I take the delayed value out because the memory accesses are not coalesed as beam one will want sample 8, beam two will want sample 15, beam three will want sample 31 of channel one, then something similar will happen to channel two, etc. And suddenly I have barely any parallelisation and the beamformer grinds to a halt and cant run in real time. The amount of data I have for each channel exceeds 1024 and the maximum delays for the beams can exceed 1024.
Are there any sources of information which show an efficient way to deal with these problems where strided access to memory occurs a lot in cuda?
