string segmentation problem : upcase_trim_adjustl
:-) Hello .
;-) This time a problem ( extracted form Meso-NH ) with strings routines .
We try to manage the string read in NAMELIST in a reproducible form, so we use this kind or routine/statement :
UPCASE(TRIM(ADJUSTL(HSTATU)))
No problem with g95/gfortran/ifort
bug_pgi> g95 test_upcase_trim_adjustl.f90 -o test_upcase_trim_adjustl
bug_pgi> test_upcase_trim_adjustl
TEST :: sub_upcase_trim_adjustl
HSTATU >>>> keep <<<<
YSTATU = UPCASE(TRIM(ADJUSTL(HSTATU))) >>>>KEEP###<<<<
PASSED :: sub_upcase_trim_adjustl
With pgf90 ( 10.9 ) Segmentation Violation ( ;-) in French in the text )
bug_pgi> pgf90 test_upcase_trim_adjustl.f90 -o test_upcase_trim_adjustl
Erreur de segmentation
Here is the test code “test_upcase_trim_adjustl.f90”
Bye Juan
MODULE mode_sub
CONTAINS
  FUNCTION UPCASE(HSTRING)
    IMPLICIT NONE
    CHARACTER(LEN=*)            :: HSTRING
    CHARACTER(LEN=LEN(HSTRING)) :: UPCASE
    INTEGER :: JC
    INTEGER, PARAMETER :: IAMIN = IACHAR("a")
    INTEGER, PARAMETER :: IAMAJ = IACHAR("A")
    DO JC=1,LEN(HSTRING)
       IF (HSTRING(JC:JC) >= "a" .AND. HSTRING(JC:JC) <= "z") THEN
          UPCASE(JC:JC) = ACHAR(IACHAR(HSTRING(JC:JC)) - IAMIN + IAMAJ)
       ELSE
          UPCASE(JC:JC) = HSTRING(JC:JC)
       END IF
    END DO
  END FUNCTION UPCASE
  SUBROUTINE sub_upcase_trim_adjustl(HSTATU)
    IMPLICIT NONE
    CHARACTER(LEN=*),  INTENT(IN)  :: HSTATU  ! status for the closed file
    ! local variable
    CHARACTER(LEN=LEN(HSTATU))     :: YSTATU
    YSTATU = UPCASE(TRIM(ADJUSTL(HSTATU))) // "######"
    print*,"  HSTATU                                 >>>>" , HSTATU ,"<<<<"
    print*,"  YSTATU = UPCASE(TRIM(ADJUSTL(HSTATU))) >>>>" , YSTATU ,"<<<<"
  END SUBROUTINE sub_upcase_trim_adjustl
END MODULE mode_sub
PROGRAM test_upcase_trim_adjustl
  USE mode_sub
  IMPLICIT NONE
  CHARACTER(LEN=7)     :: CSTATU
  CSTATU = " keep "
  print*," TEST   :: sub_upcase_trim_adjustl  "
  CALL sub_upcase_trim_adjustl(CSTATU)
  print*," PASSED :: sub_upcase_trim_adjustl  " ; print*
END PROGRAM test_upcase_trim_adjustl
we recreated your behavior with the current compilers, and we have
logged it as TPR 17413. The line it fails on is
regards,
dave
:-) Thank you Dave .
Bye
A work-around is to rearrange the upcase call,e .g.,
TRIM(UPCASE(ADJUSTL(HSTATU)))
regards,
dave
TPR 17413 has been fixed as of the 12.10 release.
thanks,
dave
