struc containing pointer?
Hi All,
I would like to define a set of arrays that I will pass to some kernel. Since I might have many of them, it might be simpler to organized them in a struct. I would then like to do something like :
[codebox]
struct data{
float *val;
device data mydata;
global void init(float *in){
mydata.val = in;
global void kernel(float *out){
int tid = threadIdx.x;
out[tid] = (mydata.val)[tid];
[/codebox]
But this is not working. Is there a simple way to store the address of a global mem object in a device struct?
thanks
[codebox]
struct struct_of_arrays
int *array0;
int *array1;
int *arrayN;
global
void foo(struct_of_arrays soa)
soa.array0[tid] = tid;
soa.array1[tid] = tid;
soa.arrayN[tid] = tid;
int main(void)
struct_of_arrays soa;
cudaMalloc((void**)&soa.array0, …);
cudaMalloc((void**)&soa.array1, …);
cudaMalloc((void**)&soa.arrayN, …);
foo<<<…,…>>>(soa);
return 0;
[/codebox]
Thanks to both of you.
Now I see what I was doing wrong and how to do it right…
cheers
