Struct as template argument problem
Look at this code, please:
File test.cu:
[codebox]
struct S{};
template global void template_test() {
float4 f = make_float4( 0, 0, 0, 0 );
//int a;
void test() {
dim3 g( 1, 1, 1 );
dim3 b(1, 1, 1 );
template_test<S><<<g,b>>>();
[/codebox]
It compiles without errors.
Now uncomment //int a and comment float4 :
[codebox]
struct S{};
//float4 f = make_float4( 0, 0, 0, 0 );
int a;
void test() {
dim3 g( 1, 1, 1 );
dim3 b(1, 1, 1 );
[/codebox]
Nvcc output:
[codebox]
1>Executing tool NVCC_CUDA on file d:\SciArtSVN\Sciart\PluginSystem\GpuBoard\test.cu, result Tmp\Debug\test.obj
1>test.cu
1>d:/SciArtSVN/Sciart/PluginSystem/GpuBoard/test.cu(5): warning: variable “a” was declared but never referenced
1> detected during instantiation of “void template_test() [with T=S]”
1>(11): here
1>tmpxft_00000d30_00000000-3_test.cudafe1.gpu
1>tmpxft_00000d30_00000000-8_test.cudafe2.gpu
1>tmpxft_00000d30_00000000-3_test.cudafe1.cpp
1>tmpxft_00000d30_00000000-13_test.ii
1>d:/SciArtSVN/Sciart/PluginSystem/GpuBoard/test.cu(11) : error C2065: ‘template_test__entry’ : undeclared identifier
1>d:/SciArtSVN/Sciart/PluginSystem/GpuBoard/test.cu(11) : error C2275: ‘S’ : illegal use of this type as an expression
1> d:/SciArtSVN/Sciart/PluginSystem/GpuBoard/test.cu(1) : see declaration of ‘S’
1>d:/SciArtSVN/Sciart/PluginSystem/GpuBoard/test.cu(11) : error C2059: syntax error : ‘)’
1>C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000d30_00000000-3_test.cudafe1.stub.c(10) : error C2275: ‘S’ : illegal use of this type as an expression
1>C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000d30_00000000-3_test.cudafe1.stub.c(10) : error C2059: syntax error : ‘)’
1>C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000d30_00000000-3_test.cudafe1.stub.c(23) : error C2143: syntax error : missing ‘;’ before ‘<’
1>C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000d30_00000000-3_test.cudafe1.stub.c(23) : error C2182: ‘__wrapper__device_stub_template_test’ : illegal use of type ‘void’
1>C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000d30_00000000-3_test.cudafe1.stub.c(23) : error C2988: unrecognizable template declaration/definition
1>C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000d30_00000000-3_test.cudafe1.stub.c(23) : error C2059: syntax error : ‘<’
1>C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000d30_00000000-3_test.cudafe1.stub.c(25) : error C2143: syntax error : missing ‘;’ before ‘{’
1>C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000d30_00000000-3_test.cudafe1.stub.c(25) : error C2447: ‘{’ : missing function header (old-style formal list?)
[/codebox]
What the hell is going on??
I coudn’t use Struct as template arguments in my kernels,
any help will be appreciated
After renaming test() to main() and it compiles fine on my system:
[codebox]$ cat test.cu
include <cuda.h>
struct S{};
template
int a;
int main(void)
dim3 g( 1, 1, 1 );
dim3 b(1, 1, 1 );
$ nvcc test.cu
test.cu(9): warning: variable “a” was declared but never referenced
$ nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2009 NVIDIA Corporation
Built on Thu_Apr__9_05:05:52_PDT_2009
Cuda compilation tools, release 2.2, V0.2.1221[/codebox]
CUDA 2.2 has much better template support than 2.1, so make sure that you have it installed (w/ nvcc --version)
Thanks for the reply.
the same code on my computer generates following error:
[codebox]
test.cu
      detected during instantiation of "void template_test<T>() [with T=S]"
(16): here
tmpxft_00000ef4_00000000-3_test.cudafe1.gpu
tmpxft_00000ef4_00000000-8_test.cudafe2.gpu
tmpxft_00000ef4_00000000-3_test.cudafe1.cpp
tmpxft_00000ef4_00000000-13_test.ii
test.cu(16) : error C2065: ‘template_test__entry’ : undeclared identifier
test.cu(16) : error C2275: ‘S’ : illegal use of this type as an expression
    test.cu(3) : see declaration of 'S'
test.cu(16) : error C2059: syntax error : ‘)’
C:\DOCUME~1\Sieciech\LOCALS~1\Temp/tmpxft_00000ef4_00000000-3_test.cudafe1.stub.
e ‘void’
[/codebox]
[indent]
–version
Built on Sat_May__2_13:16:30_PDT_2009
Cuda compilation tools, release 2.2, V0.2.1221[/indent]
version is the same as yours. I don’t understand this error messages.
I’ve been using template kernels with CUDA 2.1 and they were working fine. Now with version 2.2 I have these errors. I made another test script
template <int a>
__global__ void kernelA(int * r)//error
	*r = a;
	int c;
template <int a>
__global__ void kernelB(int * r)//OK
	*r = 0;
template <int a>
__global__ void kernelC(int * r)//error
	int c;
	*r = 0;
template <class A>
__global__ void kernelD(int * r)//OK
	A a=0;
	*r = 0;
void f(){
	kernelA<10><<<1,1>>>(0);//error C2065: kernelA__entry undeclared identifier
	kernelB<10><<<1,1>>>(0);//OK
	kernelC<10><<<1,1>>>(0);//error C2065: kernelC__entry undeclared identifier
	kernelD<int><<<1,1>>>(0);//OK
It is WIN32 Cuda compilation tools, release 2.2, V0.2.1221.
I found that compiling with switch
–host-compilation C
actually makes it work, but some C++ features like exceptions will be disabled.
Thank you very much. It helps.
Maybe nVidia fix this bug in new release
So the problem occurs when there is a warning reported in a template kernel.
After fixing warnings I was able to compile my kernels with --host-compilation C++
(To launch my kernels I need all the data structures which means lots of C++, and I can’t separate the code because textures can only be global file-scope).
Thanks for reporting this bug.
It will be fixed in the 2.3 release.
