I would like to define a struct which does not only have functions which are only host but also member variables. It is because I don’t need these on the device and would like to save that space on the device.
I don’t believe it is legal to specify memory types like that inside structures. What follows is completely idle speculation. I have absolutely no idea whether it could work or not:
nvcc speaks a little C++, so it might be possible to do something close to what you want via class inheritance, ie. define a base class which holds just the data you want to use on the device, then define derived classes from the base class which decorates it with whatever host functionality you need to add. Some casting magic and polymorphism on the part of the host can probably give you back the base class when you need to move it to GPU memory.
