Struct vs. parameters performance difference
Hello. I’m pretty new to Cuda, and I’ve got a question about a performance difference I’m seeing.
When I pass in all my data as a bunch of arrays as parameters to my kernel function, I’m seeing the best performance.
But, when I passed it in as an array of structs, I saw worse performance. But then I learned about coalescing, so then I refactored my struct to contain a bunch of arrays and passed in a single struct that contained a bunch of arrays and that greatly improved performance.
But I’m still seeing a difference in performance between the coalesced struct parameters method, and the bunch-of-arrays parameter method that I don’t understand.
Do you folks know why passing in a bunch of parameters would still result in better performance than passing in a struct that contain a bunch of coalesced data?
This was done in google colab using a T4 GPU
code (bunch-of-parameters):
%%writefile TestProg.cu
include
include <math.h>
include <assert.h>
include “cuda_fp16.h”
using namespace std;
define MAX_NUM_THREADS_PER_BLOCK 1024
define gpuErrorCheck(ans) { gpuAssert((ans), FILE, LINE); }
inline void gpuAssert(cudaError_t code, const char *file, int line, bool abort=true)
if (code != cudaSuccess)
fprintf(stderr,“GPUassert: %s %s %d\n”, cudaGetErrorString(code), file, line);
if (abort) exit(code);
global void run(half2 *y, half2 *m, half2 *x, half2 *b, int num)
int index = blockIdx.x * blockDim.x + threadIdx.x;
int stride = blockDim.x * gridDim.x;
for (int i = index; i < num; i += stride)
y[i] = m[i]*x[i] + b[i];
int main ()
int num = 1024 * 1024;
half2 *y = NULL;
half2 *m = NULL;
half2 *x = NULL;
half2 *b = NULL;
cudaMallocManaged(&y, sizeof(half2) * num);
cudaMallocManaged(&m, sizeof(half2) * num);
cudaMallocManaged(&x, sizeof(half2) * num);
cudaMallocManaged(&b, sizeof(half2) * num);
for (int i = 0; i < num; i++)
y[i] = __float2half2_rn(2.0f);
m[i] = __float2half2_rn(2.0f);
x[i] = __float2half2_rn(2.0f);
b[i] = __float2half2_rn(2.0f);
int deviceId;
cudaGetDevice(&deviceId);
cudaMemPrefetchAsync(y, sizeof(half2) * num, deviceId);
cudaMemPrefetchAsync(m, sizeof(half2) * num, deviceId);
cudaMemPrefetchAsync(x, sizeof(half2) * num, deviceId);
cudaMemPrefetchAsync(b, sizeof(half2) * num, deviceId);
gpuErrorCheck(cudaPeekAtLastError());
gpuErrorCheck(cudaDeviceSynchronize());
int numberOfBlocks = (num + MAX_NUM_THREADS_PER_BLOCK - 1) / MAX_NUM_THREADS_PER_BLOCK;
run<<<numberOfBlocks, MAX_NUM_THREADS_PER_BLOCK>>>(y, m, x, b, num);
return 0;
code (coalesced struct):
include
//include <math.h>
//include <assert.h>
struct foo
int num;
half2 *y = NULL;
half2 *m = NULL;
half2 *x = NULL;
half2 *b = NULL;
foo (int num) : num(num)
int deviceId;
device inline void bar()
global void run(foo *foos, int num)
foos->bar();
int main ()
foo *foos = NULL;
cudaMallocManaged(&foos, sizeof(foo));
new (foos) foo(num);
int deviceId;
cudaMemPrefetchAsync(foos, sizeof(foo), deviceId);
run<<<numberOfBlocks, MAX_NUM_THREADS_PER_BLOCK>>>(foos, num);
return 0;
performance:
Compilation command:
!nvcc TestProg.cu -o TestProg
Run command:
!nvprof ./TestProg
Thanks again for the help!!
please format code correctly on these forums. Edit your post with the pencil icon, select the code, click </> button, save your changes. Please do not post pictures of text
Sorry, it looks like it won’t let me update my own post. So I guess I’ll reply to it instead haha :D
Here is the struct option which is slightly slower than the parameters way of doing it.
#include <iostream>
#include "cuda_fp16.h"
#define MAX_NUM_THREADS_PER_BLOCK 1024
#define gpuErrorCheck(ans) { gpuAssert((ans), __FILE__, __LINE__); }
      fprintf(stderr,"GPUassert: %s %s %d\n", cudaGetErrorString(code), file, line);
struct foo
  int num;
  half2 *y = NULL;
  half2 *m = NULL;
  half2 *x = NULL;
  half2 *b = NULL;
    int deviceId;
  __device__ inline void bar()
__global__ void run(foo *foos, int num)
  foos->bar();
int main ()
  foo *foos = NULL;
  int deviceId;
  return 0;
Results for struct method:
==2525== NVPROF is profiling process 2525, command: ./TestProg
==2525== Profiling application: ./TestProg
==2525== Profiling result:
            Type  Time(%)      Time     Calls       Avg       Min       Max  Name
 GPU activities:  100.00%  172.73us         2  86.365us  85.374us  87.357us  run(foo*, int)
      API calls:   97.32%  112.84ms         5  22.569ms  12.318us  112.76ms  cudaMallocManaged
                    1.79%  2.0749ms         3  691.63us  86.349us  1.8975ms  cudaDeviceSynchronize
                    0.51%  587.38us         5  117.48us  3.6540us  383.61us  cudaMemPrefetchAsync
                    0.23%  269.55us         2  134.78us  6.8140us  262.74us  cudaLaunchKernel
                    0.12%  140.31us       114  1.2300us     143ns  56.608us  cuDeviceGetAttribute
                    0.01%  11.512us         1  11.512us  11.512us  11.512us  cuDeviceGetName
                    0.01%  8.7580us         2  4.3790us  1.5620us  7.1960us  cudaGetDevice
                    0.00%  5.6930us         1  5.6930us  5.6930us  5.6930us  cuDeviceGetPCIBusId
                    0.00%  4.7510us         1  4.7510us  4.7510us  4.7510us  cuDeviceTotalMem
                    0.00%  1.5600us         3     520ns     200ns  1.1170us  cuDeviceGetCount
                    0.00%  1.3000us         3     433ns     184ns     655ns  cudaPeekAtLastError
                    0.00%     934ns         2     467ns     193ns     741ns  cuDeviceGet
                    0.00%     577ns         1     577ns     577ns     577ns  cuModuleGetLoadingMode
                    0.00%     218ns         1     218ns     218ns     218ns  cuDeviceGetUuid
==2525== Unified Memory profiling result:
Device "Tesla T4 (0)"
   Count  Avg Size  Min Size  Max Size  Total Size  Total Time  Name
       9  1.7782MB  4.0000KB  2.0000MB  16.00391MB  1.393567ms  Host To Device
Total CPU Page faults: 49
Code for the faster ‘parameters’ method.
#include <iostream>
#include <math.h>
#include <assert.h>
__global__ void run(half2 *y, half2 *m, half2 *x, half2 *b, int num)
int main ()
  half2 *y = NULL;
  half2 *m = NULL;
  half2 *x = NULL;
  half2 *b = NULL;
  int deviceId;
  return 0;
Performance results:
==3162== NVPROF is profiling process 3162, command: ./TestProg
==3162== Profiling application: ./TestProg
==3162== Profiling result:
 GPU activities:  100.00%  147.04us         2  73.518us  72.478us  74.559us  run(__half2*, __half2*, __half2*, __half2*, int)
      API calls:   73.26%  113.91ms         4  28.477ms  11.944us  113.84ms  cudaMallocManaged
                   24.93%  38.767ms         2  19.384ms  6.7890us  38.761ms  cudaLaunchKernel
                    1.29%  2.0100ms         3  669.99us  71.610us  1.8603ms  cudaDeviceSynchronize
                    0.38%  597.47us         4  149.37us  3.9200us  399.73us  cudaMemPrefetchAsync
                    0.11%  167.85us       114  1.4720us     137ns  60.944us  cuDeviceGetAttribute
                    0.01%  11.983us         1  11.983us  11.983us  11.983us  cuDeviceGetName
                    0.00%  6.8000us         1  6.8000us  6.8000us  6.8000us  cudaGetDevice
                    0.00%  5.5540us         1  5.5540us  5.5540us  5.5540us  cuDeviceGetPCIBusId
                    0.00%  4.6420us         1  4.6420us  4.6420us  4.6420us  cuDeviceTotalMem
                    0.00%  1.7600us         3     586ns     194ns  1.2380us  cuDeviceGetCount
                    0.00%  1.6600us         3     553ns     176ns     772ns  cudaPeekAtLastError
                    0.00%     862ns         2     431ns     181ns     681ns  cuDeviceGet
                    0.00%     603ns         1     603ns     603ns     603ns  cuModuleGetLoadingMode
                    0.00%     259ns         1     259ns     259ns     259ns  cuDeviceGetUuid
==3162== Unified Memory profiling result:
       8  2.0000MB  2.0000MB  2.0000MB  16.00000MB  1.389215ms  Host To Device
Total CPU Page faults: 48
Yeah so the performance is close, but I’m curious as to the actual theoretical reason for any difference.
Thanks again for the help :D
Why don’t you pass the struct by value instead of pointer? With pointer, you have a double indirection to access the half2 arrays.
For other differences, you can inspect the SASS code.
Ok cool. Thanks, I’ll give that a try.
What are the pro’s/con’s of pass by value in this context? Will the host still have access to that struct if I wanted to process some data on the host side after the kernel runs?
(Sorry still new to all this haha :D )
Pass by value is passing a copy. So changes on the device won’t be seen on the host. But if the passed struct is from a host variable, this original host variable can still be accessed.
Yeah that was it. By doing pass by value I achieved pretty much identical results to passing all the arrays individually to the kernel.
Thanks!!
