I hope this is not a problem already reported. But there seems to be some PTX code generation problem with copying structures. The clBuildProgram returns errors with code that copies a structure on global address space to another.
The error looks like this:
ptxas ptx input, line 56; fatal : Parsing error near ‘.’: syntax error
: Retrieving binary for ‘anonymous_jit_identity’, for gpu=‘sm_13’, usage mode=’
The following is an example:
typedef struct
int x;
int y;
int z;
int w;
} SomeStructure;
__kernel void test_calc_kernel(__global void *heap)
__global SomeStructure *s1 = (__global SomeStructure *) heap;
__global SomeStructure *s2 = s1 + 1;
*s1 = *s2;
However, if I copy the structure to a __private structure as an intermediate step, it doesn’t complain. For example,
SomeStructure c;
*s1 = c = *s2;
As far as I know, structure copy should be legal in OpenCL. Well, the workaround depends on that in any case case. But I may be wrong.
I am using CUDA 2.3 running on GTX 295 if that makes any difference. Thanks.
