In my browser, after I click on the button to upload the docs I see this error:
Refused to load the script ‘https://www.redditstatic.com/ads/pixel.js’ because it violates the following Content Security Policy directive: “script-src https://forums.developer.nvidia.com/logs/ https://forums.developer.nvidia.com/sidekiq/ https://forums.developer.nvidia.com/mini-profiler-resources/ https://global.discourse-cdn.com/nvidia/assets/ https://global.discourse-cdn.com/nvidia/brotli_asset/ https://forums.developer.nvidia.com/extra-locales/ https://sea2.discourse-cdn.com/nvidia/highlight-js/ https://sea2.discourse-cdn.com/nvidia/javascripts/ https://sea2.discourse-cdn.com/nvidia/plugins/ https://sea2.discourse-cdn.com/nvidia/theme-javascripts/ https://sea2.discourse-cdn.com/nvidia/svg-sprite/ assets.adobedtm.com/b92787824f2e0e9b68dc2e993f9bd995339fe417/satelliteLib-7ba51e58dc61bcb0e9311aadd02a0108ab24cc6c.js https://assets.adobedtm.com/ ‘unsafe-eval’ https://c1.rfihub.net/ https://a.rfihub.com/”. Note that ‘script-src-elem’ was not explicitly set, so ‘script-src’ is used as a fallback.
(anonymous) @ satellite-5fc7be3364746d49f3001a74.js:1
followed by this warning:
Deprecation notice: whiteList
has been replaced with allowList
(deprecated since Discourse 2.6.0.beta.4) (removal in Discourse 2.7.0)
e.default @ _application-b0ec9d999839cf612893bbcc84904ded07108b42f586004970e193e2d04401e3.js:609
so when I click on the link to see allowed filetypes it lists: ()
Auth.log is 4990Kb
Nucleus - Access.log is 24Kb
The zip of both files is 50Kb
I just tried uploading the zip again and was met with:
Connection refused - connect(2) for “261f0ebb040f.tiefighter03.sd.sjc6.discourse.cloud” port 16726
In addition, I tried to uninstall Nucleus but that filed also so I tried it from the command line directly and got the following;
12/25/2020 10:48 PM 1,284 nucleus-setup.exe.manifest
2 File(s) 1,544,212 bytes
0 Dir(s) 650,959,015,936 bytes free
D:\Omniverse\Library\collaboration\nucleus-workstation 2020.3.0\setup>nucleus-setup -u
uninstall
File “D:\Omniverse\Library\collaboration\nucleus-workstation 2020.3.0\setup\toml\decoder.py”, line 456, in loads
multibackslash)
File “D:\Omniverse\Library\collaboration\nucleus-workstation 2020.3.0\setup\toml\decoder.py”, line 725, in load_line
value, vtype = self.load_value(pair[1], strictly_valid)
File “D:\Omniverse\Library\collaboration\nucleus-workstation 2020.3.0\setup\toml\decoder.py”, line 788, in load_value
raise ValueError(“Reserved escape sequence used”)
ValueError: Reserved escape sequence used
During handling of the above exception, another exception occurred:
File “nucleus-setup.py”, line 291, in
File “nucleus-setup.py”, line 280, in main
File “nucleus-setup.py”, line 168, in uninstall
File “nucleus-setup.py”, line 230, in stop_system_monitor
File “D:\Omniverse\Library\collaboration\nucleus-workstation 2020.3.0\setup\toml\decoder.py”, line 112, in load
return loads(ffile.read(), _dict, decoder)
File “D:\Omniverse\Library\collaboration\nucleus-workstation 2020.3.0\setup\toml\decoder.py”, line 458, in loads
raise TomlDecodeError(str(err), original, pos)
toml.decoder.TomlDecodeError: Reserved escape sequence used (line 2 column 1 char 7)
[21552] Failed to execute script nucleus-setup
Inside the launcher I tried simply rolling back to using 2020.3.0 instead of the 2021.1.1 I am currently running but selecting the older Nucleus version also just pops up a command prompt which vanishes immediately and, again, nothing happened. I am still on the 2021.1.1 version.
As I said before, The entire Omniverse suite seems confused about itself and is completely unusable … even to the point where I can’t even uninstall it :(
