I am trying to setup the code as provided in this repo: GitHub - Daniel595/Jetson_nano_face_recognition: face recognition using MTCNN, Dlib face embeddings, Dlib SVMs
I have had no issues setting up dlib previously and using the face_recognition library. OpenCV, CUDA, and everything else seems to be working. To be sure I have even used a fresh SD Card and set everything up there.
It instructs me to edit the CMakeLists.txt file, and update it with the directories on my nano, however I cannot find the correct tensorrt directory. I have /usr/src/tensorrt, however this does not contain an include directory as indicated in the text file
When I try to actually run cmake, it throws multiple complaints about the find_package lines in the txt file, indicating that it cannot find either dlib, or Boost. OpenCV is found as long as I use the correct version.
If anyone could point me in the right direction to fix this that would be amazing. I’m a little lost with where to look - quite a beginner when it comes to cmake
