Stuck at grub after last update
I’m stuck at grub after the last firmware update and system does not seem to see Linux. Please advise what commands I should use to get back online without losing data. TIA!
I’m stuck on the black Boot screen which says
GNU GRUB version 2.12
Minimal BASH-like line editing is supported. For the first word, TAB lists possible command completions. Anywhere else TAB lists possible device or file completions. To enable less(1)-like paging, “set pager=1”.
grub>
This happened after the latest update and reboot. Any help is appreciated. Thanks!
Besides rebuild from USB stick I’m not sure there are many options. This means losing everything that was on the node unfortunately.
I’m rebuilding from USB but checking a workaround. This last firmware update was brutal :(
I have Claude Code inspecting in from another node. There seems to be some header damage. Here’s to hoping fixing the disk ID actually works.
Looks like the workaround and files are in tact (I’ve yet to inspect everything). I’ll have Claude write a summary and share. It seems like the firmware forced shut down caused a corrupt partition. The update caused a write to land in the wrong place and it overwrote the filesystem’s main header.
That is rather impressive to break it that way.
