I’m trying to clone again the nvidia tx2i that is working using this command:
sudo ./flash.sh -r -k APP -G backup.img jetson-tx2i mmcblk0p1
but i get stuck again at:
[ 7.0109 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 7.0121 ] number of images in blob are 9
[ 7.0134 ] blobsize is 4087784
[ 7.0140 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 225152
[ 7.0172 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 122272
[ 7.0192 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 58384
[ 7.0215 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2298464
[ 7.0215 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 534816
[ 7.0216 ] Added binary blob_tegra186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1_sigheader.dtb.encrypt of size 76160
[ 7.0216 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 403264
[ 7.0217 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 7.0217 ] Added binary blob_tegra186-quill-p3489-1000-a00-00-ucm1_sigheader.dtb.encrypt of size 367680
[ 7.0218 ]
[ 7.0219 ] Sending bootloader and pre-requisite binaries
[ 7.0246 ] tegrarcm_v2 --download blob blob.bin
[ 7.0261 ] Applet version 01.00.0000
[ 7.0483 ] Sending blob
[ 7.0488 ] […] 100%
[ 16.8942 ]
[ 16.8979 ] tegrarcm_v2 --boot recovery
[ 16.8993 ] Applet version 01.00.0000
[ 16.9243 ]
[ 17.9291 ] tegrarcm_v2 --isapplet
if i run dmesg i get this output:
[ 6883.255174] usb 3-2: new high-speed USB device number 33 using xhci_hcd
[ 6883.406218] usb 3-2: New USB device found, idVendor=0955, idProduct=7018, bcdDevice= 0.00
[ 6883.406221] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6883.406222] usb 3-2: Product: APX
[ 6883.406223] usb 3-2: Manufacturer: NVIDIA Corp.
[ 6883.406223] usb 3-2: SerialNumber: 00000
[ 7130.133370] INFO: task tegrarcm_v2:55502 blocked for more than 120 seconds.
[ 7130.133376] Not tainted 5.4.0-100-generic #113~18.04.1-Ubuntu
[ 7130.133378] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 7130.133380] tegrarcm_v2 D 0 55502 55324 0x20020000
[ 7130.133384] Call Trace:
[ 7130.137735] __schedule+0x292/0x720
[ 7130.137935] schedule+0x33/0xa0
[ 7130.137970] schedule_timeout+0x15d/0x320
[ 7130.138908] ? __next_timer_interrupt+0xe0/0xe0
[ 7130.138917] wait_for_completion_timeout+0xb3/0x140
[ 7130.139003] ? wake_up_q+0x80/0x80
[ 7130.139668] usb_start_wait_urb+0xe3/0x180
[ 7130.139674] usb_bulk_msg+0xb8/0x160
[ 7130.139697] proc_bulk+0x257/0x3a0
[ 7130.139704] usbdev_do_ioctl+0x93d/0x1490
[ 7130.140356] ? handle_mm_fault+0xcb/0x210
[ 7130.140449] usbdev_compat_ioctl+0x10/0x20
[ 7130.140541] __ia32_compat_sys_ioctl+0x105/0x230
[ 7130.140592] do_int80_syscall_32+0x5b/0x130
[ 7130.140596] entry_INT80_compat+0x85/0x90
[ 7130.140598] RIP: 0023:0x807a744
[ 7130.140603] Code: Bad RIP value.
[ 7130.140604] RSP: 002b:00000000ffd97a58 EFLAGS: 00000283 ORIG_RAX: 0000000000000036
[ 7130.140606] RAX: ffffffffffffffda RBX: 0000000000000005 RCX: 00000000c0105502
[ 7130.140607] RDX: 00000000ffd97a80 RSI: 0000000000000010 RDI: 0000000008eaf688
[ 7130.140608] RBP: 00000000ffd97ae0 R08: 0000000000000000 R09: 0000000000000000
[ 7130.140608] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
[ 7130.140609] R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
For the other board, the one where i flashed with last jetpack 4.6 and that the usb isn’t working, i do the following:
1 - power it in recovery mode
2 - connect it to ubuntu 18
and this is the dmesg and lsusb output:
[ 7593.079670] usb 3-2: New USB device found, idVendor=0955, idProduct=7018, bcdDevice= 0.00
[ 7593.079674] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7593.079676] usb 3-2: Product: APX
[ 7593.079678] usb 3-2: Manufacturer: NVIDIA Corp.
Bus 003 Device 037: ID 0955:7018 NVidia Corp.
I try to replace the dtb Linux_for_Tegra/kernel/dtb/tegra186-quill-p3489-1000-a00-00-ucm1.dtb with the downloaded file File:Tegra186-tx2-usb-base.tar.gz - eLinux.org as suggested in the elinux tutorial Jetson/TX2 USB - eLinux.org and flash it using the command:
sudo ./flash.sh -r -k kernel/dtb/tegra186-quill-p3489-1000-a00-00-ucm1.dtb jetson-tx2i mmcblk0p1
but after flashing it won’t boot…
What i’m doing wrong?
Thanks for reply
