This is another confirmed case of the state described in threads 376039, 376239, 366944, 362737, 375687, 376542 and 378150, with numbers and a detector.
Unit: Gigabyte AI TOP ATOM (GB10), DGX OS 7.2.3, driver 580.178.04, kernel 6.17.0-1032-nvidia, PD firmware 5.22/5.0.
Timeline (same day)
- 16:59 local: last healthy sample under load, 2073 MHz, 28.3 W.
- 17:17: first stuck sample, 676 MHz, 8.5 W.
- It appeared between two boots (healthy 16:55–17:08, stuck from 17:08 on). The three following boots: 100 % of the samples with GPU utilisation ≥ 80 % were below 1000 MHz.
Stuck state: SM clock 663 MHz (max 3003, default application clock 2418), 16.4 W, utilisation 95 %, throttle reasons 0x0, 23.5 TFLOPS on an fp16 8192×8192 matmul. nvidia-smi -lgc is accepted and ignored. A reboot does not clear it.
Remedy (reported by community members in 376039 and 376239 and repeated by an NVIDIA moderator in 376039; not an NVIDIA-documented procedure; the waits reported range from 5 minutes in 376239 to “up to 8 hours” in 376039, where one user says it did not work): power off, unplug the AC adapter from the wall (and USB), hold the power button ~10 s, wait a few minutes, reconnect. On my unit it cleared: 2080 MHz, 67 W, 77.4 TFLOPS on the same test. I have no healthy baseline from before, so 77.4 is a post-fix reading, not a spec.
Side-effect I could not rule out (hypothesis, not proven): thread 381549 says the fan is mainly controlled by the GPU temperature, and 383821 reports sustained CPU temperatures above 86 °C with the fans essentially quiet. With the GPU stuck and cold, the CPU/SoC zones heated with the fans low. My unit also cut power once after hours in that state. I have no evidence that the stuck clock caused the cut.
Detector (open, part of GitHub - lcasarin-maker/blackbox: Prevention, diagnosis and forensics for NVIDIA GB10 AI workstations (DGX Spark, ASUS Ascent GX10, Gigabyte AI TOP ATOM): Xid, thermal, OOM, stuck-GPU-clock detector, per-cgroup GPU memory (dmem patch), guardrails · GitHub): bb reloj --prueba runs a ~15 s matmul and samples clock/power/throttle with nvidia-smi. Three verdicts: STUCK (median < 1000 MHz with load and no throttle reasons), HEALTHY (≥ 1400 MHz, the threshold used by the tool in 362737), INDETERMINATE (no load or in between; it never reports healthy without load). A boot-time timer runs it six minutes after boot, because this time it took me ~8 hours to notice. It uses the smoke test from 366944 and the 1400 MHz threshold from 362737.
Not known: the root cause (power delivery / PD negotiation?), why some units do not recover, and whether 7.2.3 changes anything.
Questions for NVIDIA
- Can the driver report a throttle reason (or any signal) for this state?
- Is there a firmware/PD fix planned, or should the power cycle be the documented procedure?
- Can the fan curve also consider CPU/SoC temperature on partner units?
