Stuck in Pixar Storm config - unable to select RTX
I initially launched Code without a compatible RTX card and now it is stuck using Pixar Storm as the renderer. I have added a RTX 4060Ti but I am unable to select it from the rendering settings without the following errors:
2024-01-23 08:23:58 [Error] [omni.ui.python] TypeError: ‘>’ not supported between instances of ‘NoneType’ and ‘int’
2024-01-23 08:23:58 [Error] [omni.ui.python] At:
2024-01-23 08:23:58 [Error] [omni.ui.python] c:\users\xxxxxxxx\appdata\local\ov\pkg\code-2022.3.3\kit\exts\omni.rtx.settings.core\omni\rtx\settings\core\widgets\pt_widgets.py(32): _build_ui
2024-01-23 08:23:58 [Error] [omni.ui.python] c:\users\xxxxxxxx\appdata\local\ov\pkg\code-2022.3.3\kit\exts\omni.rtx.window.settings\omni\rtx\window\settings\settings_collection_frame.py(151): build_ui
2024-01-23 08:23:58 [Error] [omni.ui.python] TypeError: ‘<’ not supported between instances of ‘int’ and ‘NoneType’
2024-01-23 08:23:58 [Error] [omni.ui.python] c:\users\xxxxxxxx\appdata\local\ov\pkg\code-2022.3.3\kit\exts\omni.rtx.settings.core\omni\rtx\settings\core\widgets\pt_widgets.py(141): clamp
2024-01-23 08:23:58 [Error] [omni.ui.python] c:\users\xxxxxxxx\appdata\local\ov\pkg\code-2022.3.3\kit\exts\omni.rtx.settings.core\omni\rtx\settings\core\widgets\pt_widgets.py(143): _build_ui
2024-01-23 08:23:58 [Error] [omni.ui.python] c:\users\xxxxxxzx\appdata\local\ov\pkg\code-2022.3.3\kit\exts\omni.rtx.window.settings\omni\rtx\window\settings\settings_collection_frame.py(151): build_ui
thanks for any help
Mark
@mark_pickford i am just another OV user passing by, is it possible for you to upload the most recent .log file as an attachment for more in-depth review? you can find the file directory here:
%userprofile%\.nvidia-omniverse\logs\Kit\Code
Hi Simplychenable,
Thanks for passing by. I’ve uploaded the log file, hopefully it makes some sense to you?
Appreciate you taking a look.
Mark
kit_20240120_153648.log (918.6 KB)
could you try one thing real quick? close out of any OV app you may have opened (including the launcher), go into C:\users\mark pickford\appdata\local\ov\data\Kit\Code, and delete the version folders and see if that changes anything. there are other possible factors, but wanted to try one thing at a time.
That did it :-) RTX loaded successfully. Really grateful for you taking a look. I’ve probably spent 1/2 a day deleting and reinstalling Code and OV.
thanks again Mark
Glad to hear. Yes that folder contains all of your app settings…
