Stuck on boot logo after update
Hi there,
yesterday i tried to update my jetson nano 2gb model and after the restart I’m stuck at the boot logo.
What I’ve tried so far:
  • reflash the SD-Card
  • flash another SD-Card
  • several images (JP44, JP45, JP451)
  • flash over sdkmanager
  • flash with flash.sh
  • setup a bootable USB
so far nothing worked and I don’t know what I can try next to fix this problem.
The serial outputs the following messages:
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[0000.130] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.138] Power-up reason: pmc por
[0000.141] No Battery Present
[0000.144] pmic max77620 reset reason
[0000.147] pmic max77620 NVERC : 0x50
[0000.151] RamCode = 1
[0000.153] Platform has DDR4 type RAM
[0000.156] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0xb0ab8
[0000.172] Entering ramdump check
[0000.175] Get RamDumpCarveOut = 0x0
[0000.178] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.188] Sdram initialization is successful
[0000.192] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.198] Lp0 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.204] BpmpFw Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.210] GSC1 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.216] Resize the SecureOs Carveout to 0x00100000
[0000.221] GSC2 Carveout Base=0x00000000ff900000 Size=0x00100000
[0000.226] GSC4 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.232] GSC5 Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.238] GSC3 Carveout Base=0x00000000bf800000 Size=0x00200000
[0000.244] RamDump Carveout Base=0x0000000000000000 Size=0x00000000
[0000.250] Platform-DebugCarveout: 0
[0000.253] Nck Carveout Base=0x00000000ff800000 Size=0x00000000
[0000.259] Non secure mode, and RB not enabled.
[0000.263] BoardID = 3448, SKU = 0x3
[0000.266] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.270] Nano-SD: checking PT table on QSPI …
[0000.274] Read PT from (2:0)
[0000.290] Using BFS PT to query partitions
[0000.295] Loading Tboot-CPU binary
[0000.324] Verifying TBC in OdmNonSecureSBK mode
[0000.334] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.341] Bootloader downloaded successfully.
[0000.345] Downloaded Tboot-CPU binary to 0xa0000258
[0000.350] MAX77620_GPIO5 configured
[0000.353] CPU power rail is up
[0000.356] CPU clock enabled
[0000.360] Performing RAM repair
[0000.363] Updating A64 Warmreset Address to 0xa00002e9
[0000.368] BoardID = 3448, SKU = 0x3
[0000.371] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.375] Nano-SD: checking PT table on QSPI …
[0000.379] Loading NvTbootBootloaderDTB
[0000.446] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.525] Bootloader DTB Load Address: 0x83000000
[0000.530] BoardID = 3448, SKU = 0x3
[0000.533] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.537] Nano-SD: checking PT table on QSPI …
[0000.542] Loading NvTbootKernelDTB
[0000.608] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.687] Kernel DTB Load Address: 0x83100000
[0000.691] BoardID = 3448, SKU = 0x3
[0000.695] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.698] Nano-SD: checking PT table on QSPI …
[0000.705] Loading cboot binary
[0000.820] Verifying EBT in OdmNonSecureSBK mode
[0000.862] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.869] Bootloader downloaded successfully.
[0000.873] BoardID = 3448, SKU = 0x3
[0000.877] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.880] Nano-SD: checking PT table on QSPI …
[0000.885] PT: Partition NCT NOT found !
[0000.889] Warning: Find Partition via PT Failed
[0000.893] Next binary entry address: 0x92c00258
[0000.897] BoardId: 3448
[0000.902] Overriding pmu board id with proc board id
[0000.907] Display board id is not available
[0000.911] No Bpmp FW loaded
[0000.914] Not loading WB0 as no bpmp/sc7entry fw
[0000.918] Set NvDecSticky Bits
[0000.922] GSC2 address ff93fffc value c0edbbcc
[0000.928] GSC MC Settings done
[0000.931] BoardID = 3448, SKU = 0x3
[0000.934] QSPI-ONLY: SkipQspiOnlyFlag = 0
[0000.938] Nano-SD: checking PT table on QSPI …
[0000.943] TOS Image length 53680
[0000.946] Monitor size 53680
[0000.949] OS size 0
[0000.964] Secure Os AES-CMAC Verification Success!
[0000.969] TOS image cipher info: plaintext
[0000.973] Loading and Validation of Secure OS Successful
[0000.989] NvTbootPackSdramParams: start.
[0000.994] NvTbootPackSdramParams: done.
[0000.997] Tegraboot started after 51830 us
[0001.001] Basic modules init took 922517 us
[0001.005] Sec Bootdevice Read Time = 12 ms, Read Size = 61 KB
[0001.011] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.016] Next stage binary read took 11286 us
[0001.021] Carveout took -63807 us
[0001.024] CPU initialization took 99953 us
[0001.028] Total time taken by TegraBoot 969949 us
[0001.032] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):5b49e7f80
NOTICE: BL31: Built : 14:33:23, Jan 15 2021
ERROR: Error initializing runtime service trusty_fast
[0001.154] RamCode = 1
[0001.159] LPDDR4 Training: Read DT: Number of tables = 2
[0001.164] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.176] EMC Training Successful
[0001.179] 408000 not found in DVFS table
[0001.186] RamCode = 1
[0001.189] DT Write: emc-table@204000 succeeded
[0001.195] DT Write: emc-table@1600000 succeeded
[0001.199] LPDDR4 Training: Write DT: Number of tables = 2
[0001.237]
[0001.238] Debug Init done
[0001.240] Marked DTB cacheable
[0001.243] Bootloader DTB loaded at 0x83000000
[0001.248] Marked DTB cacheable
[0001.251] Kernel DTB loaded at 0x83100000
[0001.255] DeviceTree Init done
[0001.268] Pinmux applied successfully
[0001.272] gicd_base: 0x50041000
[0001.276] gicc_base: 0x50042000
[0001.279] Interrupts Init done
[0001.283] Using base:0x60005090 & irq:208 for tick-timer
[0001.288] Using base:0x60005098 for delay-timer
[0001.292] platform_init_timer: DONE
[0001.296] Timer(tick) Init done
[0001.300] osc freq = 38400 khz
[0001.303]
[0001.305] Welcome to L4T Cboot
[0001.308]
[0001.309] Cboot Version: 00.00.2018.01-t210-39562017
[0001.314] calling constructors
[0001.317] initializing heap
[0001.319] initializing threads
[0001.322] initializing timers
[0001.325] creating bootstrap completion thread
[0001.329] top of bootstrap2()
[0001.332] CPU: ARM Cortex A57
[0001.335] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.340] initializing platform
[0001.348] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.352] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.357] Macronix QSPI chip present
[0001.360] SPI device register
[0001.363] init boot device
[0001.365] allocating memory for boot device(SPI)
[0001.370] registering boot device
[0001.378] QSPI bdev is already initialized
[0001.382] Enable APE clock
[0001.385] Un-powergate APE partition
[0001.388] of_register: registering tegra_udc to of_hal
[0001.394] of_register: registering inv20628-driver to of_hal
[0001.399] of_register: registering ads1015-driver to of_hal
[0001.405] of_register: registering lp8557-bl-driver to of_hal
[0001.411] of_register: registering bq2419x_charger to of_hal
[0001.416] of_register: registering bq27441_fuel_gauge to of_hal
[0001.428] gpio framework initialized
[0001.431] of_register: registering tca9539_gpio to of_hal
[0001.437] of_register: registering tca9539_gpio to of_hal
[0001.442] of_register: registering i2c_bus_driver to of_hal
[0001.447] of_register: registering i2c_bus_driver to of_hal
[0001.453] of_register: registering i2c_bus_driver to of_hal
[0001.459] pmic framework initialized
[0001.462] of_register: registering max77620_pmic to of_hal
[0001.468] regulator framework initialized
[0001.471] of_register: registering tps65132_bl_driver to of_hal
[0001.477] initializing target
[0001.483] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.491] board ID = D78, board SKU = 3
[0001.495] Skipping Z3!
[0001.500] fixed regulator driver initialized
[0001.519] initializing OF layer
[0001.522] NCK carveout not present
[0001.525] Skipping dts_overrides
[0001.529] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.546] I2C Bus Init done
[0001.549] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.559] I2C Bus Init done
[0001.562] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.572] I2C Bus Init done
[0001.575] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.585] I2C Bus Init done
[0001.588] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.598] I2C Bus Init done
[0001.601] of_children_init: Ops found for compatible string maxim,max77620
[0001.611] max77620_init using irq 118
[0001.616] register ‘maxim,max77620’ pmic
[0001.621] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.627] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.637] I2C Bus Init done
[0001.641] NCK carveout not present
[0001.651] Find /i2c@7000c000’s alias i2c0
[0001.655] get eeprom at 1-a0, size 256, type 0
[0001.664] Find /i2c@7000c500’s alias i2c2
[0001.668] get eeprom at 3-a0, size 256, type 0
[0001.672] get eeprom at 3-ae, size 256, type 0
[0001.676] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.682] I2C slave not started
[0001.685] I2C write failed
[0001.687] Writing offset failed
[0001.690] eeprom_init: EEPROM read failed
[0001.694] pm_ids_update: eeprom init failed
[0001.698] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.729] pm_ids_update: The pm board id is 3448-0003-400
[0001.735] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.744] pm_ids_update: pm id update successful
[0001.749] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.779] pm_ids_update: The pm board id is 3542-0000-201
[0001.785] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0001.793] pm_ids_update: pm id update successful
[0001.823] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.829] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.837] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.843] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.851] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:d8:4d
[0001.858] Plugin Manager: Parse ODM data 0x000a4000
[0001.871] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0001.886] Find /i2c@7000c000’s alias i2c0
[0001.890] get eeprom at 1-a0, size 256, type 0
[0001.899] Find /i2c@7000c500’s alias i2c2
[0001.902] get eeprom at 3-a0, size 256, type 0
[0001.907] get eeprom at 3-ae, size 256, type 0
[0001.911] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.916] I2C slave not started
[0001.919] I2C write failed
[0001.922] Writing offset failed
[0001.925] eeprom_init: EEPROM read failed
[0001.929] pm_ids_update: eeprom init failed
[0001.933] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.963] pm_ids_update: The pm board id is 3448-0003-400
[0001.970] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0001.976] pm_ids_update: pm id update successful
[0001.981] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.011] pm_ids_update: The pm board id is 3542-0000-201
[0002.017] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0002.024] pm_ids_update: pm id update successful
[0002.055] Add serial number:1424120069884 as DT property
[0002.063] Applying platform configs
[0002.069] platform-init is not present. Skipping
[0002.074] calling apps_init()
[0002.080] Couldn’t find GPT header
[0002.084] Proceeding to Cold Boot
[0002.087] starting app android_boot_app
[0002.091] Device state: unlocked
[0002.094] display console init
[0002.103] could not find regulator
[0002.106] hdmi cable connected
[0002.121] edid read success
[0002.139] DT entry for leds-pwm not found
[0002.142] edid read success
[0002.145] width = 640, height = 480, frequency = 25174825
[0002.150] width = 640, height = 480, frequency = 25174825
[0002.156] width = 2560, height = 1440, frequency = 241500000
[0002.161] width = 2560, height = 1440, frequency = 595500000
[0002.167] width = 1920, height = 1080, frequency = 148351648
[0002.173] width = 1920, height = 1080, frequency = 148351648
[0002.178] width = 1280, height = 720, frequency = 74175824
[0002.184] width = 1280, height = 720, frequency = 74175824
[0002.189] width = 720, height = 480, frequency = 26973026
[0002.195] width = 720, height = 576, frequency = 26973026
[0002.200] width = 720, height = 480, frequency = 26973026
[0002.205] width = 720, height = 576, frequency = 26973026
[0002.211] width = 640, height = 480, frequency = 25174825
[0002.216] Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.224] tmds-config node not found
[0002.228] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.243] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.250] could not find regulator
[0002.254] could not find regulator
[0002.257] could not find regulator
[0002.285] using default cmu settings
[0002.289] dc_hdmi_enable, starting HDMI initialisation
[0002.295] dc_hdmi_enable, HDMI initialisation complete
[0002.300] list and configure display window
[0002.309] display console init completed
[0002.320] subnode volume_up is not found !
[0002.324] subnode back is not found !
[0002.328] subnode volume_down is not found !
[0002.332] subnode menu is not found !
[0002.335] Gpio keyboard init success
[0002.416] found decompressor handler: lz4-legacy
[0002.431] decompressing blob (type 1)…
[0002.500] load_bmp_blob: panelresolution=1080 type=3
[0002.574] decompressor handler not found
[0002.578] load_firmware_blob: Firmware blob loaded, entries=2
[0002.584] XUSB blob version 0 size 124416 @ 0x934ae28c
[0002.590] -------> se_aes_verify_sbk_clear: 747
[0002.594] se_aes_verify_sbk_clear: Error
[0002.598] SE operation failed
[0002.601] bl_battery_charging: connected to external power supply
[0002.613] device_query_partition_size: failed to open partition spiflash0:MSC !
[0002.620] MSC Partition not found
[0002.627] device_query_partition_size: failed to open partition spiflash0:USP !
[0002.634] USP partition read failed!
[0002.637] blob_init: blob-partition USP header read failed
[0002.643] android_boot Unable to update recovery partition
[0002.648] kfs_getpartname: name = LNX
[0002.652] Loading kernel from LNX
[0002.661] Found 19 BFS partitions in “spiflash0”
[0002.979] load kernel from storage
[0002.984] decompressor handler not found
[0003.247] Successfully loaded kernel and ramdisk images
[0003.252] board ID = D78, board SKU = 3
[0003.257] sdmmc node status = okay
[0003.260] sdcard instance = 0
[0003.263] sdcard gpio handle 0x5a
[0003.266] sdcard gpio pin 0xc9
[0003.269] sdcard gpio flags 0x0
[0003.272] vmmc-supply 0x9d
[0003.275] cd_gpio_pin = 201
[0003.278] pin_state = 0
[0003.280] Found sdcard
[0003.282] SD-card IS present …
[0003.285] load_and_boot_kernel: SD card detected OK
[0003.291] load_bmp_blob: panelresolution=1080 type=3
[0003.777] display bmp image done
[0003.780] NCK carveout not present
[0003.783] Skipping dts_overrides
[0003.786] NCK carveout not present
[0003.796] Find /i2c@7000c000’s alias i2c0
[0003.800] get eeprom at 1-a0, size 256, type 0
[0003.809] Find /i2c@7000c500’s alias i2c2
[0003.813] get eeprom at 3-a0, size 256, type 0
[0003.817] get eeprom at 3-ae, size 256, type 0
[0003.821] pm_ids_update: Updating 1,a0, size 256, type 0
[0003.827] I2C slave not started
[0003.830] I2C write failed
[0003.832] Writing offset failed
[0003.835] eeprom_init: EEPROM read failed
[0003.839] pm_ids_update: eeprom init failed
[0003.843] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.874] pm_ids_update: The pm board id is 3448-0003-400
[0003.881] Adding plugin-manager/ids/3448-0003-400=/i2c@7000c500:module@0x50
[0003.889] pm_ids_update: pm id update successful
[0003.894] pm_ids_update: Updating 3,ae, size 256, type 0
[0003.924] pm_ids_update: The pm board id is 3542-0000-201
[0003.930] Adding plugin-manager/ids/3542-0000-201=/i2c@7000c500:module@0x57
[0003.938] pm_ids_update: pm id update successful
[0003.968] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.974] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0003.982] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.988] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0003.996] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:2e:d8:4d
[0004.003] Plugin Manager: Parse ODM data 0x000a4000
[0004.016] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[0004.024] Add serial number:1424120069884 as DT property
[0004.032] Updated bpmp info to DTB
[0004.037] Updated initrd info to DTB
[0004.041] “proc-board” doesn’t exist, creating
[0004.047] Updated board info to DTB
[0004.050] “pmu-board” doesn’t exist, creating
[0004.056] Updated board info to DTB
[0004.060] “display-board” doesn’t exist, creating
[0004.066] Updated board info to DTB
[0004.069] “reset” doesn’t exist, creating
[0004.074] Updated reset info to DTB
[0004.077] Cmdline: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dv
[0004.114] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[0004.120] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0004.133] Updated bootarg info to DTB
[0004.136] Adding uuid 00000001644612c0140000000efe8580 to DT
[0004.142] Adding eks info 0 to DT
[0004.148] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0004.154] Updated memory info to DTB
[0004.162] set vdd_core voltage to 1125 mv
[0004.166] setting ‘vdd-core’ regulator to 1125000 micro volts
[0004.171] Found secure-pmc; disable BPMP
U-Boot 2020.04-g6b630d64fd (Jan 15 2021 - 14:33:20 -0800)
SoC: tegra210
Model: NVIDIA Jetson Nano 2GB Developer Kit
Board: NVIDIA P3541-0000
DRAM: 2 GiB
MMC:
Maybe someone here has an idea what to do next.
kind regards
Is there any log after “MMC:”? It is abnormal to just stop at this line.
Can you directly attach the log as a text file instead of using copy and paste?
Hi Wayne,
thanks for your reply but unfortunately that’s where it gets stuck all the time. Even after 12h+ nothing changes. I also tried to erase my whole SD-Card and create a new Ext4 partition but it was without success.
I attached the log.
log.txt (17.3 KB)
This should not be set during this log, right?
Could you share me the flash log from flash.sh and what was the uart log after that?
Hi Wayne,
yes, right now I’m using a SD-Card. I’m also booting from a minimal config (HDMI + power) if it matters.
Again, it’s stopping at “MMC:”, but I’ve attached the logs
log_uart.txt (17.3 KB) log_flash.txt (14.2 KB)
Did this board ever work before?
If not, I would suggest you can RMA this device. Your steps look correct so I don’t think it is software issue.
Hey Wayne,
it worked flawless before the update. Do you have any suggestions that I can try to maybe fix it?
  1. What was the command to do the update? Is it sudo apt-get upgrade?
  2. I think the sdkmanager should flash that back. Since you already tried all the methods, I think there is no other methods. But if you still want to dig into this issue, maybe you can add some debug print in uboot.
In a normal boot up case, it should have something like below. Need to see what get stuck in that “MMC:” line.
   U-Boot 2020.04-g6b630d64fd (Jan 02 2021 - 15:47:52 -0800)
    SoC: tegra210
    Model: NVIDIA Jetson Nano Developer Kit
    Board: NVIDIA P3450-0000
    DRAM:  4 GiB
    MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
    Loading Environment from SPI Flash... SF: Detected mx25u3235f with page size 256 Bytes, erase size 4 KiB, total 4 MiB
    *** Warning - bad CRC, using default environment
    In:    serial
    Out:   serial
    Err:   serial
    Net:   No ethernet found.
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    Scanning mmc 1:1...
Hi Wayne,
shouldn’t it be normal, that this line : U-Boot 2020.04-g6b630d64fd (Jan 15 2021 - 14:33:20 -0800) should change depending on the JetPack release I flash? Thats actually sth that caught my eye since this line never changes (date and version) so maybe it’s something to look into or should it stay the same all the time?
Also, do you have any links that can guide me to add debug prints?
If you fallback to jetpack 4.4.x will you see that time back to 2020? Since jetpack4.4.x is a release in 2020, it should be 2020 timestamp.
As for building the uboot, maybe you can download the source code from dlc first.
Steps for build:
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/uboot_guide.html#wwpID0E0JK0HA
Alrighty, I fixed the problem by reflashing JP4.4.1 via sdkmanager! Just a wild guess, but I think the u-boot broke during the update (or something similar) since the version didn’t change when I flashed different versions. Everythings working as expected again :). Thank you Wayne for guiding me in the right direction!
