I had flashed and used a my Jetson Orin Nano Dev Kit for a couple months.
One day it booted to and got stuck on the POST screen, I tried going into “BIOS manages” but the second I try that the Jetson will completely freeze. So I tried reflashing it and SDKmanager gets stuck on " Waiting for target to boot-up…" and device behaves the same way as before.
I also tried using an SD Cards instead and NVMe but no changes.
Please try sdk manager to flash again and provide the log pressing EXPORT LOGS button if issue exists.
I did, I thought I attached it, I must have missed it. Today I will be trying a different ubuntu machine to see fi that was the issue.
SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_Nano_[8GB_developer_kit_version]_2025-05-18_15-11-42.zip (291.3 KB)
It appears that your apt server has some issue.
Please only choose Jetson Linux and run the sdk manager again.
Hey I was able to get help from someone else. Before starting the flash process I ran “- sudo systemctl restart rpcbind”
I do appreciate the help though!
