Hi.
I downloaded nsight-training.
- The current Eclipse version differs from the one in the video - no major issue.
- Nature requires adaptations - also managed that one - step 1 finished!
Now I get this one here for step 2:
Error with command: ${cuda_tk_bin:/step_1}/cuda-gdb --version
Cannot run program "${cuda_tk_bin:/step_1}/cuda-gdb": Unknown reason
Replacing ${cuda_tk_bin:/step_1}/cuda-gdb
with /usr/bin/cuda-gdb
did the job.
Somehow, variable cuda_tk_bin
was not set properly. I manually corrected that one as well.
… later (step 1) …
After manual fix in the Eclipse Debug Configuration section, .cuda-gdbinit
wasn’t found … ;(
I found out that deleting .cuda-gdbinit
did the job.
Why is not present in the filesystem or why is it entered in the Debug Configuration if not required?
… later (step 1) …
When gdb is run and hits main, I select Resume. gdb stops at the build-in bug. The left Eclipse Debug pane shows differently as in video, and the right Variables pane doesn’t show any variables at all, but this here:
Multiple errors reported.
1) Failed to execute MI command:
-var-create - * pResult
Error message from debugger back end:
-var-create: unable to create variable object
2) Unable to create variable object
3) Failed to execute MI command:
-data-evaluate-expression pResult
No symbol "pResult" in current context.
4) Failed to execute MI command:
I’m under the impression that this tutorial was done from a heavily preconfigured Eclipse/CUDA IDE.
At the moment, I spent more time getting the devel environment ready rather than coding, optimizing, profiling … :)
Many thanks for any help.
