Respected all,
I am doing some code in cuda. I am new in cuda so i do not know much things related to that.
I want to ask that “Can we pass structure pointer to kernel ?”
waiting for response
can i do like this?
Pixel is the structure having 4 bytes
Pixel *p;
cudaMalloc((PIXEL **)p,size);
//i thing above line will create the buffer on GPU of sizeof(PIXEL)*size
//is it correct? then can i do like this
kernel<<<dimGrid,dimBlock>>>(p,…);
//passing pointer to the kernel
can i create a pointer for each structure?
like i want to access the each structure’s element into 1 thread.
like P[i].xyz = c[i];
p is structure array and c is character array.
can i do that?
timber
2
Sorry, that I do not answer directly to your question. I’m not so familiar with pointers.
In my program I use such construction:
typedef struct {
int rgb[3];
} c_m;
extern "C" void cu_img_up(bmp img_in, bmp img_out)
c_m * ca;
c_m * cc;
cudaMalloc ((void**)&ca, numBytes);
cudaMalloc ((void**)&cc, numBytes);
cudaMemcpy (ca, a, numBytes, cudaMemcpyHostToDevice);
cudaMemcpy (cc, c, numBytes, cudaMemcpyHostToDevice);
dim3 threads = dim3(3, 1);
dim3 blocks = dim3(height, width);
img_upKernel<<<blocks, threads>>>(ca, cc, height, width);
cudaMemcpy (c, cc, numBytes, cudaMemcpyDeviceToHost);
cudaFree (ca );
cudaFree (cc );
__global__ void img_upKernel (c_m* ca, c_m* cc, int h, int w)
int tx = threadIdx.x;
int idx = blockIdx.x * gridDim.y + blockIdx.y;
cc[idx].rgb[tx] = ca[idx].rgb[tx] + 40;
if (cc[idx].rgb[tx] > 255)
cc[idx].rgb[tx] = 255;
