Student Humanoid Team Sponsorship Request – Jetson AGX Thor for WiscoHumanoids (UW–Madison)
Proposal - WiscoHumanoids.pdf (10.9 MB)
Hello NVIDIA team,
I’m Jack Melzer, Mechanical Engineering Lead at WiscoHumanoids, a student robotics team at the University of Wisconsin–Madison. Our goal is to become the first undergraduate organization to design, build, and integrate a full-scale humanoid robot end to end.
Our Gen 1 humanoid is a 31-DOF, 4’5", roughly 40 kg robot. We’re currently building our 7-DOF arms, with the legs on track for test-bench assembly by December. Our compute architecture is built around a Jetson AGX Thor as the main onboard computer, running ROS 2 and our learned policies, paired with an RK3588 for real-time EtherCAT communication to the actuators and ZED X cameras for perception.
On the software side, our locomotion team has trained PPO policies in MuJoCo that produce coordinated steps on a Unitree G1 model. Our manipulation team has run successful physical pick-and-place with an ACT policy and is working toward fine-tuning the π0.5 VLA on real-world data.
We’d be grateful for any support toward a Jetson AGX Thor Developer Kit, whether through hardware sponsorship or an educational discount. In return, we’d feature NVIDIA on the robot and our website, share build and benchmark updates, and submit the project to the Jetson Community Projects page.
Our technical documentation is at wiscohumanoids.com, and I’m happy to share more details. If there’s a better contact for student team sponsorships, I’d really appreciate a pointer.
Thank you for your time,
Jack Melzer
WiscoHumanoids, University of Wisconsin–Madison
jtmelzer@wisc.edu
Thanks for your interest in NVIDIA Jetson! Unfortunately, we’re unable to fulfill hardware sponsorship requests at this time — the volume of requests we receive makes it impossible to support them individually, and we do not have a grant program to direct you to at this time.
We’d encourage you to explore purchasing Jetson through our authorized distributors, or check out the NVIDIA Jetson store for current options.
We hope you find a path to get your project off the ground, and we’d love to see what you build with the Jetson community.
