Hi @shivam.mehta,
It’s great to see you’re using MONAI Label. Thanks for opening this ticket.
In order to start the MONAI Label server, you should specify the app you’d like to use and the studies (i.e. folder in the file archive or a DICOMWeb server).
If you’re working on your local PC/laptop, you should specify a folder where the images are located.
The error you’re getting is because the --studies argument is missing.
An example to start the MONAI Label server should look like this:
monailabel start_server --app apps/radiology --studies datasets/Task09_Spleen/imagesTr --conf models segmentation
You can check more details about this here: GitHub - Project-MONAI/MONAILabel: MONAI Label is an intelligent open source image labeling and learning tool.
You may also find this video tutorial useful: MONAI Bootcamp 2021 - MONAI Label - YouTube
Please don’t hesitate to reach out to us either here or in the main MONAI Label repo: GitHub - Project-MONAI/MONAILabel: MONAI Label is an intelligent open source image labeling and learning tool.
