Hi everyone,
When cameras are used for rear-view, surround-view, or other mobility applications, image resolution is only one part of the equation. Challenging lighting, long cable runs, camera synchronization, and harsh operating conditions can have a significant impact on the overall vision system.
We recently published a closer look at STURDeCAM12, a 1.3MP automotive-grade GMSL2 camera designed for applications such as rear-view, 360° surround-view, moving-off information systems (MOIS), and blind-spot detection.
Some of the key features include:
Up to 120 dB HDR for scenes with large differences between bright and dark areas
High sensitivity for imaging in both bright daylight and low-light conditions
OMNIVISION OX01G10 1.3MP color sensor with built-in ISP
GMSL2 connectivity up to 15 m, carrying power and data over the same connection
External trigger support for synchronized multi-camera configurations
Multiple output resolutions up to 1280 × 1020 at 30 fps
IP69K-rated automotive-grade enclosure
Operating temperature range of -40°C to +85°C
Support for NVIDIA Jetson AGX Orin and Jetson Orin NX
The external trigger capability is particularly relevant for applications such as 360° surround view, where synchronized capture from multiple cameras can help create a coordinated view around the vehicle or mobility platform.
We have covered the sensor, HDR performance, GMSL2 connectivity, synchronization, environmental specifications, use cases, and customization possibilities in more detail here:
A Closer Look at e-con Systems’ Latest 120 dB HDR Rear View Camera – STURDeCAM12
If you’re working on a Jetson-based mobility or multi-camera vision system, the article may be useful when evaluating the trade-offs between resolution, HDR, connectivity, synchronization, and ruggedness.
