Subject: Rate Limit Increase Request: 40 → 200 RPM for AI Agent Workflow
Hello NVIDIA Team,
Requesting a rate limit bump for my NIM API account.
• Email: 2365360230@qq.com
• API Key (last 4): pxHn
• Current: 40 RPM
• Requested: 200 RPM
Use case: Running an AI agent cluster (Hermes Agent) for personal development. Single user, not production. The agent dispatches tasks to sub-agents — each task triggers multiple API calls in sequence. 40 RPM gets hit fast during multi-agent reasoning chains, causing 429 errors that break the workflow.
Typical flow: User prompt → Coordinator → parallel sub-agents → each making 5-10 calls → easily 30+ RPM for even a simple task.
Models in rotation: deepseek-v4-pro, llama-4-maverick, mistral-large-3, nemotron-super-49b, glm-5.1. The model diversity isn’t load-balancing — it’s deliberate A/B testing for different reasoning patterns.
Daily volume: ~2-5M tokens, single user, personal development only. Non-commercial, no external traffic.
200 RPM would be enough to stop the 429 interruptions. If there’s a higher tier available I wouldn’t say no, but 200 should cover it.
Appreciate the free tier — it’s genuinely generous. Just need the RPM breathing room to stop tripping over the floor.
