Subject: Unknown Parameter Warnings for outputTerminatedTracks, outputShadowTracks, and terminatedTrackFilename in DeepStream 6.3 Pipeline
Hello DeepStream Team,
I’m encountering warnings while trying to use the following parameters in our tracker configuration file:
  • enable-past-frame / usePastFrame
  • terminatedTrackFilename
  • outputTerminatedTracks
  • outputShadowTracks
The log outputs show:
!! [WARNING][NvTrackerParamsTargetManager] Unknown param found: outputTerminatedTracks
!! [WARNING][NvTrackerParamsTargetManager] Unknown param found: outputShadowTracks
!! [WARNING][NvTrackerParamsTargetManager] Unknown param found: terminatedTrackFilename
Target system is a Jetson AGX Xavier, though we are currently testing on an x86 server.
• DeepStream Version:
6.3
• JetPack Version (valid for Jetson only):
5.12
• TensorRT Version:
8.5.2
  1. We used a DeepStream 6.3 pipeline with our tracker YAML configuration file containing the parameters mentioned above.
  2. When launching the application, the following warnings appear in the log:
  • Unknown param found: outputTerminatedTracks
  • Unknown param found: outputShadowTracks
  • Unknown param found: terminatedTrackFilename
  1. The configuration file includes these parameters to enable features like past frame tracking and to output terminated/shadow track information.
here our yaml config :
tracker_yaml_config.txt (3.9 KB)
we tried to follow the instructions on this website :
Please let me know if you require any additional information regarding our setup or configuration.
Thank you in advance for your help!
Patrick
Please have a try with latest DeepStream 7.1. Some feature is added during DeepStream upgrade. You refered the latest document.
We have to stay on DS 6.3 - since enable past frame already was a feature back in DS5 , i thought it is not a version issue here.
Then you need check the setting in DS 6.3 doc here: Gst-nvtracker — DeepStream 6.3 Release documentation
I don’t found “outputTerminatedTracks” in DS 6.3 doc.
