Hello All,
Did anyone successfully manage to subscribe to the stage changes in a custom Omniverse extension?
Something similar to how Property widget updates on Prim selection change in the viewport or the Stage Widget. I tried digging into the Property window extension but with no luck so far!!!
Regards
Tanay Dimri
Hello @tanay-epigraph ,
you can subscribe to the stage event stream like this:
import omni.usd
def on_stage_event(event):
if event.type in [int(omni.usd.StageEventType.OPENED), int(omni.usd.StageEventType.SAVED)]:
print("stage event")
event_stream = omni.usd.get_context().get_stage_event_stream()
stage_event_sub = event_stream.create_subscription_to_pop(on_stage_event)
If you do this in you custom extension’s class, use self.stage_event_sub = … to keep the subscription alive during the lifetime of your extension.
Thank you @mmontebaur !!
Will give this a try today.
