I have my live link working between Substance and Omniverse and the model exports across fine, but it’s not picking up my materials.
Hello.
I may need a little more information but maybe we can give you a few things to try here in the meantime.
If you had Create Materials checked in Create then you may have new materials that need to be assigned to your USD in the stage panel. Compare the materials assigned to your USD to what is in your looks folder. If the proper material isn’t assigned then you should be able to drag and drop the material from the looks folder directly on to your mesh.
If this doesn’t fix your solution could you please share a screen capture with your settings in both Create and Painter? Maybe even of your mesh and Stage panel with opened looks folder?
