aswb
April 30, 2021, 9:14am
1
I am trying cross compile a sample on my host machine, But when I do sudo apt-get update, I am getting this error for some packages :
E: Failed to fetch http://de.archive.ubuntu.com/ubuntu/dists/bionic/main/binary-arm64/Packages 404 Not Found [IP: 141.30.62.26 80]
E: Failed to fetch http://de.archive.ubuntu.com/ubuntu/dists/bionic-updates/main/binary-arm64/Packages 404 Not Found [IP: 141.30.62.26 80]
E: Failed to fetch http://de.archive.ubuntu.com/ubuntu/dists/bionic-backports/main/binary-arm64/Packages 404 Not Found [IP: 141.30.62.26 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/bionic-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.38 80]
Compilation is failing (maybe because of this )…!
Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.5.0.7774
other
Host Machine Version
native Ubuntu 18.04
other
VickNV
April 30, 2021, 12:51pm
2
Hi @aswb ,
This is not nvidia related. Could you search the internet to see if any similar issue? “sudo dpkg --remove-architecture arm64” fix it?
What error messages did you see?
aswb
April 30, 2021, 3:12pm
3
/usr/local/driveworks-2.2/lib/libdriveworks.so: error adding symbols: File in wrong format
VickNV
April 30, 2021, 3:35pm
4
Please follow the following page in your host system and see if “clean” cross compilation helps. Thanks.
/usr/local/driveworks-2.2/doc/nvsdk_html/dwx_samples_building_V5L.html
aswb
April 30, 2021, 5:19pm
5
I’ve tried this already,
$ mkdir build
$ cd build
$ cmake -DCMAKE_BUILD_TYPE=Release
-DCMAKE_TOOLCHAIN_FILE=/path/to/driveworks/samples/cmake/Toolchain-V5L.cmake
-DVIBRANTE_PDK:STRING=/path/to/drive-t186ref-linux
/path/to/driveworks/samples/folder
$ make -j
$ make install
But when doing make -j, this error is occurring:
VickNV
April 30, 2021, 6:11pm
6
Please share the exact commands you ran. You have to modify some paths according to real paths.
aswb
April 30, 2021, 9:33pm
7
~$ cmake -DCMAKE_BUILD_TYPE=Release
-DCMAKE_TOOLCHAIN_FILE=../cmake/Toolchain-V5L.cmake
-DVIBRANTE_PDK:STRING=/home/aswin/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux ..
VickNV
April 30, 2021, 10:46pm
8
seems some typo. also, DriveWorks samples are under /usr/local/driveworks-2.2/samples.
aswb
May 1, 2021, 8:30am
9
I copied them to a separate directory
Please try with no copy as a baseline for yourself. One of your commands should like the following:
$ cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_TOOLCHAIN_FILE=/usr/local/driveworks/samples/cmake/Toolchain-V5L.cmake -DVIBRANTE_PDK:STRING=$HOME/nvidia/nvidia_sdk/DRIVE_Software_10.0_Linux_OS_DDPX/DRIVEOS/drive-t186ref-linux /usr/local/driveworks/samples/
