Enviroment: VMWare Ubuntu 18.04
GPU: Tesla T4
GPU driver version: 460.32.03
Cuda version:11.1
Cudnn version:8.1.0.77
After installing tensorrt. The follow error occured.
daniel@admin:~$ sudo dpkg -i nv-tensorrt-repo-ubuntu1804-cuda11.1-trt7.2.2.3-ga-20201211_1-1_amd64.deb
(Reading database … 89285 files and directories currently installed.)
Preparing to unpack nv-tensorrt-repo-ubuntu1804-cuda11.1-trt7.2.2.3-ga-20201211_1-1_amd64.deb …
Unpacking nv-tensorrt-repo-ubuntu1804-cuda11.1-trt7.2.2.3-ga-20201211 (1-1) over (1-1) …
Setting up nv-tensorrt-repo-ubuntu1804-cuda11.1-trt7.2.2.3-ga-20201211 (1-1) …
daniel@admin:~$ sudo apt-key add /var/nv-tensorrt-repo-cuda11.1-trt7.2.2.3-ga-20201211/7fa2af80.pub
OK
daniel@admin:~$ sudo apt update
Get:1 file:/var/nv-tensorrt-repo-cuda11.1-trt7.2.2.3-ga-20201211 InRelease
Ign:1 file:/var/nv-tensorrt-repo-cuda11.1-trt7.2.2.3-ga-20201211 InRelease
Get:2 file:/var/nv-tensorrt-repo-cuda11.1-trt7.2.2.3-ga-20201211 Release [574 B]
Hit:4 Index of /ubuntu bionic InRelease
Hit:5 Index of /ubuntu bionic-updates InRelease
Hit:6 Index of /ubuntu bionic-backports InRelease
Hit:7 Index of /ubuntu bionic-security InRelease
Reading package lists… Done
Building dependency tree
Reading state information… Done
41 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
daniel@admin:~$ sudo apt install tensorrt
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
tensorrt : Depends: libnvinfer7 (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvinfer-plugin7 (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvparsers7 (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvonnxparsers7 (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvinfer-bin (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvinfer-dev (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvinfer-plugin-dev (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvparsers-dev (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvonnxparsers-dev (= 7.2.2-1+cuda11.1) but it is not going to be installed
Depends: libnvinfer-samples (= 7.2.2-1+cuda11.1) but it is not going to be installed
How can i solve this problem?
