Suitable Power Adapter for Jetson AGX Orin Devkit 64GB
I was working in the Jetson AGX Orin DevKit and there was an unexpected power surge due to some electrical work going on. Now The Person is not powering on if i use the Adapter. I suspect that the adapter got damaged and hence the Module is not powering on. So suggest some alternative Power Adapter type C that is compatible with the module so i can check if the module is still working or is it just the adapter. The In-box adapter seems quite inaccesible. Any alternative easy accesible ones could be helpful.
According to the Jetson AGX Orin Series Supported Component List, the Jetson AGX Orin Dev Kit USB-C power adapter is a Sparkle FSP090-A1BR3 90W. The product page for the power adapter is https://www.fsp-ps.de/en/product/adapter/1546486479-1423.html, so you can compare the specs of USB-C adapters available to you with the Sparkle spec.
I actually looked into this brand before. I asked their customer service last week, and it seems they’ve updated it to FSP100-A2BR3 now. If you’re worried about getting the old version, you might want to double-check the model number with the seller before ordering.
https://www.fsp-group.com/en/product/adapter/1784258121-1548.html
