Sun Study with Camera
How do I render an animation using “Movie Type” in Sunstudy, where the camera moves? I created the move, added the sequence and selected “Camera” - Sequence Camera with the movements, but in the render the camera does not move while the sun effect occurs. I’m using USD Composer 2022.3.5
Yes I understand. Unfortunately, this is an older system that does not work that well. It does not work directly with the stage timeline animation, so you cannot create a “moving” sun study. It was designed for a static perspective view. The way to do this today is to put it back to a regular “sequence” and then the normal timeline animation will work again, and then you would have to animate the raw sun shader parameters.
