Super Nano Not Reading SD CARD IMAGE
I recently purchased a Super Nano Orin.
I issue I am facing is that the Super Nano is not reading the SD and thus not loading the OS.
I have taken the following step in alignment with NVIDIA’s Starting Guide:
1- Installed Jetson Nano Developer Kit SD Card Image
2 - Powered On Device
I have included an image showing the end result when powering on.
I need to know what steps to take to get the OS on the SD card running on the Super Nano.
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Thank You.
Hopefully I will be able to get the proper response.
Please refer to this official doc.
What’s your JP image version?
I just downloaded it last weekend so. The most recent one?
Hi, you might check your UEFI version first.
Please refer to the above mentioned guide line to check.
On the unable to load problem I saw the same Alias(s) error when trying the 6.2 Jet Pack SD card
I downloaded the JP513 image and that did update something but I am not sure about the next steps. I would have thought the SD card should have proceeded to load the images but the system just blanks th
e screen and hangs
I have checked my firmware. Looks like it’s the old firmware. I am going to install Jetpack 5.1x on the SD as stated in the previous link your sent. Then I will follow the remaining steps like update the firmware. Then I will reinstall the Jetpack 6.x on the SD and reply back if it doesn’t work.
Thank You
let me know how it goes.
Okay, thank you. This is working now.
I followed the steps from your link. My Duper Nano is now live! :)
A question I had how do I determine if I have a super nano Orin vs a regular nano Orin if the boxes are identical…
I got a bit further too but not much.
I put the SD card in a USB carrier . The boot setup found it and I got a message saying LT4xxx attempting to boot.
The screen then went blank. End of story
Could you execute below commands and share results with us?
cat /etc/nv_tegra_release
