I purchased my nvidia jetson orin nano from amazon. When I tried out, I ran out of return window. I am trying to connect IMX 219 camera but failed. So, I replaced the same camera with another one but still failed.
I need your support to connect IMX219. Why is my nano soooooooooo slow?
Thank you.
I did all the debugs Gemini suggested but none of them got me to the solutions.
What’s do you mean slow?
Do you enable the IMX219 by jetson-io?
Yes I tried but still I cannot enable it yet. There are lot more commands that I tried by following Gemini prompts but no luck.
Run the jetson-io by below command.
sudo /opt/nvidia/jetson-io/jetson-io.py
A window pops up and close instantly. It does not give enough time to see what is in that window.
can you connect my jetson nano remotely and debug that way? It will take long time otherwise. Thank you.
Please flash the system image by sdkmamager to run the jetson-io to try.
I tried following ways and it did not work. I will try to flash using sdkmanager which needs another ubuntu machine which i need to manage. What JetPack version should I install now? BTW, why is this so slow? when I type there is a lag between the time I type on the keyboard and when it shows up on my jetson nano. This seems like old days Pentium computer.
Do you remote to Orin Nano by ssh or connect keyboard to it directly?
Do you try nvpmodel to select different power mode and run the jetson_clocks to verify.
sudo nvpmodel -m *
sudo jetson_clocks
No I do not remotely connect to nvidia jetson nano.
I tried to flash the system image, now my micro sd card is broken. I bought another sandisk sd card (128GB) and asked an expert to help me. He could not boot it. Here I am stuck! Jetson Nano does not boot. Once I start the nano, i land a shell> command. We both tried every possible things but it does not boot at all. Expert says it is the issue with the device. Please call me and let’s have a conversation. I want to return my nano and get a new one.
