Supply for SDMMC3
Using a Jetson Nano eMMC module on a custom board. The Nano SDMMC3 is wired to a WiFi chip through SDIO (1.8V only). When using the below device tree settings for the vqmmc-supply it works, but the settings don’t make any sense to me.
How should the supplies and pins be set for correct operation?
file: tegra210-porg-p3448-common.dtsi
sdmmc-io-pads {
	pins = "sdmmc1", "sdmmc3";
	nvidia,enable-voltage-switching;
sdhci@700b0400 {
	status = "okay";
	bus-width = <4>;
	// vqmmc-supply = <&max77620_ldo2>; // fails!!!
	vqmmc-supply = <&max77620_ldo6>; // works!!!
	// vqmmc-supply = <&max77620_sd3>; // fails!!!
	vmmc-supply = <&p3448_vdd_3v3_sys>;
	non-removable;
	cap-sdio-irq;
	keep-power-in-suspend;
	wakeup-source;
	only-1-8-v;
file: tegra210-porg-power-tree-p3448-0000-a00.dtsi
	pmc-iopower {
		iopower-sys-supply = <&max77620_sd3>;
		iopower-uart-supply = <&max77620_sd3>;
		iopower-audio-supply = <&max77620_sd3>;
		iopower-cam-supply = <&max77620_sd3>;
		iopower-pex-ctrl-supply = <&max77620_sd3>;
		iopower-sdmmc1-supply = <&max77620_ldo2>;
		iopower-sdmmc3-supply = <&max77620_sd3>; // works!!!
		iopower-sdmmc4-supply = <&max77620_sd3>;
		iopower-audio-hv-supply = <&max77620_sd3>;
		iopower-debug-supply = <&max77620_sd3>;
		iopower-dmic-supply = <&max77620_sd3>;
		iopower-gpio-supply = <&max77620_sd3>;
		iopower-spi-supply = <&max77620_sd3>;
		iopower-spi-hv-supply = <&max77620_sd3>;
		iopower-sdmmc2-supply = <&max77620_sd3>;
		iopower-dp-supply = <&max77620_sd3>;
			sdmmc3_clk_pp0 {
				nvidia,pins = "sdmmc3_clk_pp0";
				nvidia,function = "sdmmc3";
				nvidia,pull = <TEGRA_PIN_PULL_NONE>;
				nvidia,tristate = <TEGRA_PIN_DISABLE>;
				nvidia,enable-input = <TEGRA_PIN_ENABLE>;
//				nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
			sdmmc3_cmd_pp1 {
				nvidia,pins = "sdmmc3_cmd_pp1";
				nvidia,pull = <TEGRA_PIN_PULL_UP>;
			sdmmc3_dat0_pp5 {
				nvidia,pins = "sdmmc3_dat0_pp5";
			sdmmc3_dat1_pp4 {
				nvidia,pins = "sdmmc3_dat1_pp4";
			sdmmc3_dat2_pp3 {
				nvidia,pins = "sdmmc3_dat2_pp3";
			sdmmc3_dat3_pp2 {
				nvidia,pins = "sdmmc3_dat3_pp2";
The “iopower-sdmmc3-supply” is set to supply “max77620_sd3”. The “sdmmc-io-pads” are set to “nvidia,enable-voltage-switching” for “sdmmc3”. When setting “vqmmc-supply” to the same supply “max77620_sd3” (1.8V only) it fails. When Setting “vqmmc-supply” to a different supply “max77620_ldo6” (1.8V or 3.3V) it works. Also, setting “vqmmc-supply” to the supply “max77620_ldo2” (1.8V or 3.3V) causes it to fail.
Setting “nvidia,io-high-voltage” to “<TEGRA_PIN_DISABLE>” causes multiple kernel crashes. Is this the correct setting for 1.8V operation?
When it works the following command works and gives the following results. Also the scope shows activity on the SDIO CLK pin (blue) and SDIO CMD pin (yellow).
# cat /sys/kernel/debug/mmc1/ios
clock:          204000000 Hz
vdd:            21 (3.3 ~ 3.4 V)
bus mode:       2 (push-pull)
chip select:    0 (don't care)
power mode:     2 (on)
bus width:      2 (4 bits)
timing spec:    6 (sd uhs SDR104)
signal voltage: 1 (1.80 V)
driver type:    0 (driver type B)
When it fails the following command fails and gives the following results. Note the “vdd” says “invalid”. The scope shows no activity on the SDIO CMD pin (yellow) when it fails, but the SDIO CLK pin (blue) does show activity.
clock:          0 Hz
actual clock:   99221 Hz
vdd:            0 (invalid)
power mode:     0 (off)
bus width:      0 (1 bits)
timing spec:    0 (legacy)
What is your hardware design here? Any schematic to share? The dts should match your hardware design. It sounds like you just keep try different parameters in device tree and don’t know what yourself is doing.
