I just found a compiler bug when using Fortran 2003 feature associate
in the scope of an ACC kernel.
Here is a very simple example for demonstrating this issue:
module mpoint
type point
real :: x, y, z
real :: tmp
end type point
end module mpoint
program main
use mpoint
implicit none
integer, parameter :: n = 10
real, allocatable :: array(:)
allocate(array(n))
array(:) = 1.0
call vecadd
if(abs(array(2) - 9.0)>0.01) then
write(*,*) 'GPU result is wrong!'
else
write(*,*) 'Test passed!'
end if
contains
subroutine vecadd()
integer :: i
type(point) :: A
associate( x => A%x, y => A%y, z => A%z, tmp => A%tmp)
!$acc parallel loop
do i = 1, n
x = i
y = i + 1
z = i + 2
tmp = x + y + z
array(i) = tmp
enddo
!!$acc parallel loop
!do i = 1, n
! A%x = i
! A%y = i + 1
! A%z = i + 2
! A%tmp = A%x + A%y + A%z
! array(i) = A%tmp
!enddo
end associate
end subroutine vecadd
end program main
Compiled with nvfortran -acc -Minfo
, it will crash at runtime:
Failing in Thread:1
call to cuStreamSynchronize returned error 700: Illegal address during kernel execution
However, if I comment out the loop and access the derived type component with a %
sign (as shown above in the commented out part), it will work.
In my understanding, the associate statement can be implemented by the compiler as simple as a text replacement before any IR being generated. Based on the experiment here, clearly nvfortran
has something more complicated.
