When compiling this code (using PGI 15.1 compiler)
unsigned char counter = 0;
#ifdef _OPENACC
#pragma acc kernels
#pragma acc loop independent
#endif
for( int i( 0 ); i < 100; ++i )
#ifdef _OPENACC
#pragma acc atomic update
#endif
++counter;
I get the following error
PGCC-S-0155-Invalid atomic expression (uchar.cc: 21)
PGCC-S-0155-Invalid atomic region. (uchar.cc: 21)
main:
16, Loop is parallelizable
Accelerator kernel generated
16, #pragma acc loop gang, vector(128) /* blockIdx.x threadIdx.x */
PGCC/x86 Linux 15.1-0: compilation completed with severe errors
However, when the type of variable counter is set to unsigned int, it compiles without problems.
Is this a known limitation? The standard doesn’t say anything about type restrictions for atomic.
Thank you.
L
