Hi JerryChang,
here is an image taken with TEGRA_STRIDE_ALIGNMENT 64. I cannot tell if it is better or worse, but it is not good :(
This time, the best looking picture was the raw (bytes not swapped) one.
frame-10-65535-raw.pgm.gz (2.57 MB)
Hi JerryChang,
I seems to me that what I get with the command in comment #4 is not the raw output from the sensor, but what I get is the output from the sensor processed by some other step (probably the ISP). Is that true ?
hello phdm,
the commands in comment #4 dump the raw files, which process by the V4L2 media framework.
please also refer to the [Camera Architecture Stack] from [L4T Documentation]-> [NVIDIA Tegra Linux Driver Package]-> [Release 28.2 Development Guide]-> [Camera Development] chapter-> [Camera Software Development Solution] session.
thanks
Sorry for some noise here : actually the connection to my monochrome sensor was faulty : some mipi lane was garbled. I now have another sensor that does not have that bug. Command in comment #4 (updated to my 12-bit sensor) actually gives a dump of the images sent by the sensor, with pixels stored as 16-bit big endian values : each 12-bit pixel is shifted by 4 positions to give a 16-bit value.
After adding the following entries to vi2_video_formats
TEGRA_VIDEO_FORMAT(RAW12, 12, Y12_1X12, 2, 1, T_R16_I,
RAW12, Y16_BE, "GRAY16_BE"),
TEGRA_VIDEO_FORMAT(RAW12, 12, Y12_1X12, 1, 1, T_L8,
RAW12, GREY, "GRAY8"),
and of course my driver telling that its mediabus_format is MEDIA_BUS_FMT_Y12_1X12, I now have the following list of formats :
nvidia@cam5-ubuntu:~$ v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'Y16 -BE'
Name : 16-bit Greyscale BE
Index : 1
Pixel Format: 'GREY'
Name : 8-bit Greyscale
Unfortunately, using it in a gstreamer pipeline ‘gst-launch-1.0 v4l2src …’ only gives me 2 fps.
If I let my driver pretend that its media_bus_format is MEDIA_BUS_FMT_SRGGB12_1X12, and use a gstreamer pipeline ‘gst-launch-1.0 nvcamerasrc …’ I get at least 20 fps. Why such a poor performance with v4l2src ?
Hello JerryChang,
I checked the above command on a freshly installed tx1 devkit with jetpack-3.2.1 (l4t 28.2) and equipped with a ov5693 sensor provided by nvidia. It confirms a bug in the handling of rawN sensors, with N > 8 : LSB bits are discarded !
Here is the test I made :
nvidia@tegra-ubuntu:/run/user/1001$ v4l2-ctl --list-formats-ext
Index : 0
Pixel Format: 'BG10'
Name : 10-bit Bayer BGBG/GRGR
Size: Discrete 2592x1944
Interval: Discrete 0.033s (30.000 fps)
nvidia@tegra-ubuntu:/run/user/1001$ v4l2-ctl --set-fmt-video=width=2592,height=1944,pixelformat=BG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=20 --stream-to=bg10.raw
nvidia@tegra-ubuntu:/run/user/1001$ hexdump -C bg10.raw
00000000 32 00 65 00 3a 00 5d 00 33 00 62 00 2e 00 5f 00 |2.e.:.].3.b..._.|
00000010 35 00 6d 00 39 00 57 00 3f 00 6e 00 4b 00 5d 00 |5.m.9.W.?.n.K.].|
As one can see, all the odd bytes are 0[0-3]. This is unexpected from a 10-bit sensor.
This is confirmed bye the following test
nvidia@tegra-ubuntu:/run/user/1001$ hexdump -Cv bg10.raw | grep -v '0[0-3] .. 0[0-3] .. 0[0-3] .. 0[0-3] .. 0[0-3] .. 0[0-3] .. 0[0-3] .. 0[0-3]'
0c756000
Do I misunderstand ?
Does the CSI-VI pair truncate the incoming pixels to 8 bits while also replicating the most significant bits ?
Is the image stored in memory in big endian or little endian mode ?
Is the RAW10 value shifted into 16 bits to produce values between 0 and 0xffc0, or are the 10-bits not shifted at all and produce values between 0 and 3ff ? I have read chapters 29 and 32 of the TX1 TRM, but experimental results seem not to match documentation.
Hi Honey_Patouceul
Thank you.
I have read https://devtalk.nvidia.com/default/topic/1028611/jetson-tx2/is-there-a-parameter-for-enable-disable-the-tx2-on-board-camera-/post/5274555/#5274555, and this seems to suggest that the raw10 images of the ov5693 sensor, when acquired with
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=10 --stream-to=test.raw
are actually stored in 16 bytes word, in little endian form, without any shift occuring, thus with values between 0 and 1023 (2^10-1).
This does not seem to match the TX1 TRM 31.3.2.3 “Raw Pixel Formatting to Memory”/“T_R16_I Formatting for RAW10, RAW12 and RAW14”, where RAW10 pixels are shown written in memory as
[ 0 | 0 | D9| D8| D7| D6| D5| D4| D3| D2| D1| D0| D9| D8| D7| 0 ]
, thus shifted 4 places to the left with lsb filled with some msb replication.
In a CSI->VI->MEM path, how are RAW10 or RAW12 pixels actually transformed and written into memory ?
Sorry I cannot tell much more, but the 16 bits format may only be used by option stream-to which writes to disk.
v4l2-ctl would have read into memory in RG10 format as explained by TRM, and then made the 16 bits format for disk storage with stream-to. So the raw file may not be an exact image of the memory stream. It is much easier to read just 2 bytes and get ‘short’ values for further computing, than having to manage the shifts and mask.
I am currently trying to add grayscale format support to a Jetson Xavier with L4T 31.1 by following the steps described in the above comment for the sensor OV24A1B. I started from the driver for the sensor OV5693.
In ov5693.c, I modified the default data format to match the required format (Gray 10 bits)
#define OV5693_DEFAULT_DATAFMT MEDIA_BUS_FMT_Y10_1X10
In sensor_common.c, I set the pixel format to V4L2_PIX_FMT_Y10
static int extract_pixel_format(
const char *pixel_t, u32 *format)
*format = V4L2_PIX_FMT_Y10;
return 0;
In camera_common.c, I added a camera common color formats for Grayscale
static const struct camera_common_colorfmt camera_common_color_fmts[] = {
MEDIA_BUS_FMT_SBGGR10_1X10,
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_SBGGR10,
// Grayscale support
MEDIA_BUS_FMT_Y10_1X10,
V4L2_COLORSPACE_RAW,
V4L2_PIX_FMT_Y10,
And as mentionned in the above comment, in vi2_formats.h, I added other entries to static const struct tegra_video_format vi2_video_formats :
TEGRA_VIDEO_FORMAT(RAW10, 10, Y10_1X10, 2, 1, T_R16_I,
RAW10, Y10, "GRAY10"),
RAW10, Y12, "GRAY12"),
RAW10, Y16, "GRAY16"),
However, I still get a kernel panic when running this kernel with the stack pointing to nvidia/drivers/media/platform/tegra/camera/vi/channel.c
[ 9.025262] Process kworker/1:0 (pid: 18, stack limit = 0xffffffc3ed81c028)
[ 9.032165] Call trace:
[ 9.034285] [<ffffff8008b5e8cc>] tegra_channel_fmts_bitmap_init+0x17c/0x238
[ 9.040920] [<ffffff8008b60754>] tegra_channel_init_subdevices+0x15c/0x738
[ 9.047654] [<ffffff8008b61a1c>] tegra_vi_graph_notify_complete+0x53c/0x678
[ 9.053885] [<ffffff8008b45f88>] v4l2_async_test_notify+0x108/0x120
[ 9.059911] [<ffffff8008b460cc>] v4l2_async_notifier_register+0x12c/0x1a0
[ 9.066287] [<ffffff8008b626a8>] tegra_vi_graph_init+0x210/0x290
[ 9.071633] [<ffffff8008b5ca98>] tegra_vi_media_controller_init+0x1a8/0x1e0
[ 9.078545] [<ffffff8008536340>] vi5_probe+0x340/0x390
[ 9.083096] [<ffffff80087afc50>] platform_drv_probe+0x60/0xc8
[ 9.088342] [<ffffff80087ad3dc>] driver_probe_device+0x26c/0x420
[ 9.094380] [<ffffff80087ad76c>] __device_attach_driver+0xb4/0x160
[ 9.100679] [<ffffff80087aae34>] bus_for_each_drv+0x6c/0xa8
[ 9.106363] [<ffffff80087acfb4>] __device_attach+0xcc/0x160
[ 9.111965] [<ffffff80087ad894>] device_initial_probe+0x24/0x30
[ 9.117913] [<ffffff80087ac108>] bus_probe_device+0xa0/0xa8
[ 9.123429] [<ffffff80087ac760>] deferred_probe_work_func+0x90/0xe0
[ 9.129995] [<ffffff80080d3f60>] process_one_work+0x1e0/0x478
[ 9.135769] [<ffffff80080d4444>] worker_thread+0x24c/0x4d0
[ 9.141279] [<ffffff80080dabd8>] kthread+0xe8/0x100
[ 9.145918] [<ffffff8008083500>] ret_from_fork+0x10/0x50
[ 9.151607] ---[ end trace 6425dc7be0d116c3 ]---
Do you have any ideas which step(s) am I missing to add grayscale support ?
Thanks in advance,
I do not have a Xavier, only TX1 and TX2, and while the TX1 uses the vi2_formats.h file, TX2 uses vi4_formats.h. Additions for grayscale must go there also for Xavier, I surmise.
Also, the stack trace is not the most interesting part of the error message (except for the name of the function where it happens : ‘tegra_channel_fmts_bitmap_init’ here), but there is also a panic message (probably about a null pointer). ‘printk’ is your friend :)
Oops :)
Actually, seeing ‘vi5_probe’ in your stack trace, you probably have a ‘vi5_formats.h’
Hello phdm,
Thank you for your fast answer.
I tried to put the new formats in vi5_formats.h instead of vi2_formats.h and it made v4l2-ctl happy without any kernel panic.
Thanks again,
