Please provide the following info: Software Version
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Got some issue on displaying the lidar point cloud captured from Ouster lidar OS1-64 Gen2 with 45Deg vertical field of view. Not sure if there is a support issue on this sensor. See the image below. Thank you!
The image above is from the recorded data. The same problem also occurs on live sensor data. No matter how I change the horizontal resolution and frequency, the problem could not be solved. I will capture a small batch of data and share it here later today.
FIY, the OS1-64 gen 1 with 33.2Deg FOV works fine on Pegasus.
We had captured two small data sequences to compare the problem of the Gen2 lidar. You could download them from this link.
Both lidars were set as ip=192.168.1.64, hres=1024, scan-frequency=10. Below is the command we ran to visualize the real-time data. ./sample_lidar_replay --protocol=lidar.socket --params=device=OUSTER_OS1,ip=192.168.1.64,dip=192.168.1.200,port=7502,hres=1024,scan-frequency=10 --show-intensity=true
This is the command we use to visualize the replay data: ./install/bin/sample_lidar_replay --protocol=lidar.virtual --params=file=Path/lidar_ouster.bin --show-intensity=true
Can gen 2 be configured as 33.2 degree? If yes, is this issue also reproducible on it?
Could you check this with Ouster to see if the issue is expected on your conditions (45 degree, resolution, speed, distance)?
Hi Vick,
OS1-64 Gen2 can not be configured as 33.2 Deg.
According to the DRIVE Ecosystem Hardware and Software Components, 45 Deg should be supported.
I tested both Gen1 and Gen2 sensors with the same configuration (hres:1024, frequency: 10) on a Linux system using Ouster’s software, both are fine.
Ouster support team also said that they haven’t change the data format.
These two images were rendered using the “sample_lidar_raplay” tool. The first one is from Gen1, the second one is from Gen2. They are captured at the same scene.
Gen 1 and Gen 2 are different lidars so they will have difference performances.
Please check this with Ouster. They can give you better explanation on this. Thanks!
After talking to Ouster, they said since the vertical angle is different, it will require a different config/calibration file. Do you know if we could make these changes on Pegasus?
Could you ask them to provide more information about the configuration/calibration file of Gen 2? Have they worked on it with nvidia? Are these files already part of DRIVE OS 5.2.0? What’s the file names? Thanks!
Hi Vick,
Re-open this problem since the recording tool (/usr/local/driveworks/tools/capture/recorder) has not fixed for OS1-64 Gen2. I saw the same problem on the lidar data binary file. But the sample_lidar_reply is fixed when running on the live sensor.
Could you help me if it is possible to fix the recorder BUG by myself?
Thanks for your reply!
After the inspection on DriveWorks 3.5, the live Ouster OS1-64 Gen2 lidar is working, but the recorded binary file can not be played correctly using “sample_lidar_replay” with “–protocol=lidar.virtual”. I am going to create a new post to describe the BUG.
I didn’t do anything other than installed DW3.5. But, I discovered a new BUG on the “virtual lidar” when the binary file is recorded using OS1-64 gen2. Please refer to the other post I created.
