Hello NVIDIA/NemoClaw Support Team,
I am encountering an issue while trying to install NemoClaw on my NVIDIA Jetson.
System Details
Installation Method:
I am using the following command to install:
curl -fsSL https://www.nvidia.com/nemoclaw.sh | bash
Error Description:
During the bootstrapping process, the installation script throws the following errors (as recorded in nemoclaw.log):
WARNING: Unsupported JetPack version detected. GPU may not be supported
Error: Docker did not accept the Jetson NVIDIA runtime GPU mode for managed bootstrap
This is my very first time using NemoClaw, and I plan to test it using the OpenClaw agent and Ollama with the Nemotron-3 model.
Could you please guide me on how to fix these warnings and errors so that I can successfully proceed with the NemoClaw installation and setup?
Thank you for your support.
nemoclaw.log (292 KB)
Hello @Hung_Tran!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
If cat /etc/docker/daemon.json doesn’t produce following edit it to be identical to:
"default-runtime": "nvidia",
"runtimes": {
"nvidia": {
"args": [],
"path": "nvidia-container-runtime"
Run following to try again. first 3 were extracted from your log.
sudo usermod -aG docker $USER
newgrp docker
source "${NVM_DIR:-$HOME/.nvm}/nvm.sh" && nvm use 22
curl -fsSL https://www.nvidia.com/nemoclaw.sh | bash -s -- --fresh
Thank you very much for moving my topic to the appropriate category.
This is a harmless warning from ollama.
This is a known issue and is fixed around 3 weeks ago.
Could you try it again?
https://github.com/NVIDIA/NemoClaw/issues/11197
Thank you for the guidance, I followed it, but the installation process gets stuck or throws warnings during step [6/8] Creating sandbox. I have attached the latest log file (2nd_nemoclaw.log) for your reference. For context, my system is a fresh install using NVIDIA SDK Manager with JetPack 7.2.1 (full options), and I only installed Firefox and jtop prior to running the NemoClaw installer.
2nd_nemoclaw.log (16 KB)
Thank you for the guidance. I re-flashed JetPack 7.2.1 and followed the instructions, but I am still encountering an error at step [6/8] Creating sandbox due to a timeout when pulling the Docker image. Could you please advise on how to resolve this?
You may be better off waiting for Nvidia to reply to you. but you could try
nemoclaw onboard --resume
If it fails again you could try:
sudo apt install binutils
sudo apt install --reinstall nvidia-container-toolkit nvidia-container-toolkit-base libnvidia-container-tools libnvidia-container1
CUDA_VER=$(basename "$(realpath /usr/local/cuda)" | sed 's/^cuda-//')
sudo apt install "cuda-compat-${CUDA_VER/./-}"
sudo reboot
# Then
Thank you for the guidance and troubleshooting steps provided. I followed them and generated 3rd_nemoclaw.log, but after rebooting and running the installation again, I am still encountering a timeout error during step [6/8] Creating sandbox when pulling the Docker image (spawnSync docker ETIMEDOUT), as shown in 4th_nemoclaw.log.
3rd_nemoclaw.log (13.2 KB)
4th_nemoclaw.log (13.1 KB)
I will have to wait for further guidance from NVIDIA.
You could try this to see if it will identify the entire docker image-name:value that nemoclaw attempted to pull in ‘4th nemoclaw.log’
docker images --digests --no-trunc | grep -E 'nemoclaw|openclaw'
If that returns sha256:7dcb60465421... then copy that entire actual value sha256:7dcb60465421??????????????
and
docker pull ghcr.io/nvidia/nemoclaw/openclaw-sandbox@sha256:7dcb60465421-and-the-rest-of-the-value
Then try:
I tried running docker images --digests --no-trunc | grep -E 'nemoclaw|openclaw', but it returned nothing as shown in 5th_nemoclaw.log
5th_nemoclaw.log (423 Bytes)
