Supported range of bitrate for V4l2 encoder
Hello!
I have a question regarding the V4l2 encoder bitrate:
  • Could you please recommend the values as a minimum and maximum limits for bitrate?
I am using NVidia multimedia API.
Thank you in advance.
This depends on the video quality you need in your use-case. And have to consider resolution. For example,if the resolution is 1920x1080 30fps, you can set to 12Mbps and check the video quality. And then make adjustment between 15Mbps ~ 9Mbps
Thank you for the recommendation.
One more question - what is the supported value range by ioctl driver?
It is 32-bit unsigned integer:
int NvVideoEncoder::setBitrate(uint32_t bitrate)
Thank you, @DaneLLL !
