Hello I have a IMOU IPC-F22AP PoE webcam that i can stream from (on my mac) using
vlc rtsp://admin:L2E8C359@192.168.2.8:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif latency=150 onvif-mode=true
However if i try:
~$ gst-launch-1.0 --gst-debug=rtspsrc:5 rtspsrc location=rtsp://admin:L2E8C359@192.168.2.8:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif latency=150 onvif-mode=true ! decodebin max-size-time=30000000000 ! videoconvert ! autovideosink
I receive a
0:00:00.142907259 32612 0x558a3461e0 WARN rtspsrc gstrtspsrc.c:6112:gst_rtspsrc_send:<rtspsrc0> error: Not Found (404)
– full log below –
I noted that in another thread you point to https://gstreamer.freedesktop.org/documentation/rtsp/rtspsrc.html?gi-language=c
where it says:
rtspsrc strictly follows RFC 2326 and therefore does not (yet) support RealMedia/Quicktime/Microsoft extensions.
Is this what it looks like when the stream doesn’t follow RFC 2326 ?
If so, is there a way around this ?
If this rtsp camera is not supported, is there a list of rtsp cameras that have been shown to work ?
Kind Regards,
Tom
--- log -----
[1] 32612
[2] 32613
[3] 32614
bash: onvif-mode=true: command not found
[2]- Done subtype=0
[3]+ Done unicast=true
yoda@yoda-desktop:~$ 0:00:00.063119666 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:8617:gst_rtspsrc_uri_set_uri:<rtspsrc0> parsing URI
0:00:00.063195294 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:8624:gst_rtspsrc_uri_set_uri:<rtspsrc0> configuring URI
0:00:00.063229566 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:8640:gst_rtspsrc_uri_set_uri:<rtspsrc0> set uri: rtsp://admin:L2E8C359@192.168.2.8:554/cam/realmonitor?channel=1
0:00:00.063251181 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:8642:gst_rtspsrc_uri_set_uri:<rtspsrc0> request uri is: rtsp://192.168.2.8:554/cam/realmonitor?channel=1
Setting pipeline to PAUSED ...
0:00:00.063501293 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:8391:gst_rtspsrc_start:<rtspsrc0> starting
0:00:00.063658121 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd:<rtspsrc0> sending cmd OPEN
0:00:00.063717237 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:5598:gst_rtspsrc_loop_send_cmd:<rtspsrc0> not interrupting busy cmd unknown
Pipeline is live and does not need PREROLL ...
0:00:00.063937244 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread:<rtspsrc0> got command OPEN
0:00:00.063999069 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush:<rtspsrc0> set flushing 0
0:00:00.064036466 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:4614:gst_rtsp_conninfo_connect:<rtspsrc0> creating connection (rtsp://admin:L2E8C359@192.168.2.8:554/cam/realmonitor?channel=1)...
Progress: (open) Opening Stream
0:00:00.064489554 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:4625:gst_rtsp_conninfo_connect:<rtspsrc0> sanitized uri rtsp://192.168.2.8:554/cam/realmonitor?channel=1
0:00:00.064558202 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:4659:gst_rtsp_conninfo_connect:<rtspsrc0> connecting (rtsp://admin:L2E8C359@192.168.2.8:554/cam/realmonitor?channel=1)...
Progress: (connect) Connecting to rtsp://admin:L2E8C359@192.168.2.8:554/cam/realmonitor?channel=1
0:00:00.098391258 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:7342:gst_rtspsrc_retrieve_sdp:<rtspsrc0> create options... (async)
0:00:00.098442406 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:7351:gst_rtspsrc_retrieve_sdp:<rtspsrc0> send options...
0:00:00.098543971 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send:<rtspsrc0> default handler
0:00:00.098585119 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send:<rtspsrc0> default handler
0:00:00.098602202 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send:<rtspsrc0> sending message
Progress: (open) Retrieving server options
0:00:00.107064139 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response:<rtspsrc0> received response message
0:00:00.107110494 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response:<rtspsrc0> got response message 401
0:00:00.107148829 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5785:gst_rtspsrc_setup_auth:<rtspsrc0> Attempting authentication using credentials from the URL
0:00:00.107169194 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5814:gst_rtspsrc_setup_auth:<rtspsrc0> Attempting Digest authentication
0:00:00.107204560 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send:<rtspsrc0> default handler
0:00:00.107227738 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send:<rtspsrc0> default handler
0:00:00.107248936 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send:<rtspsrc0> sending message
0:00:00.131234908 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response:<rtspsrc0> received response message
0:00:00.131283920 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response:<rtspsrc0> got response message 200
0:00:00.131317255 32612 0x558a3461e0 INFO rtspsrc gstrtspsrc.c:7364:gst_rtspsrc_retrieve_sdp:<rtspsrc0> Now using version: 1.0
0:00:00.131349599 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:7371:gst_rtspsrc_retrieve_sdp:<rtspsrc0> create describe...
0:00:00.131380694 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:7388:gst_rtspsrc_retrieve_sdp:<rtspsrc0> send describe...
0:00:00.131457311 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send:<rtspsrc0> default handler
0:00:00.131512730 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:476:default_before_send:<rtspsrc0> default handler
Progress: (open) Retrieving media info
0:00:00.131558564 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5964:gst_rtspsrc_try_send:<rtspsrc0> sending message
0:00:00.142655741 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5866:gst_rtsp_src_receive_response:<rtspsrc0> received response message
0:00:00.142705326 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:5885:gst_rtsp_src_receive_response:<rtspsrc0> got response message 404
0:00:00.142733868 32612 0x558a3461e0 WARN rtspsrc gstrtspsrc.c:5829:gst_rtspsrc_setup_auth:<rtspsrc0> error: No supported authentication protocol was found
0:00:00.142851268 32612 0x558a3461e0 WARN rtspsrc gstrtspsrc.c:6112:gst_rtspsrc_send:<rtspsrc0> error: Not found
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not open resource for reading.
Additional debug info:
gstrtspsrc.c(5829): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
0:00:00.142977574 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:7514:gst_rtspsrc_retrieve_sdp:<rtspsrc0> free connection
ERROR: pipeline doesn't want to preroll.
0:00:00.143045284 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:4715:gst_rtsp_conninfo_close:<rtspsrc0> closing connection...
Setting pipeline to READY ...
0:00:00.143136642 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:4721:gst_rtsp_conninfo_close:<rtspsrc0> freeing connection...
0:00:00.143163934 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd:<rtspsrc0> sending cmd CLOSE
0:00:00.143174664 32612 0x558a3461e0 WARN rtspsrc gstrtspsrc.c:7548:gst_rtspsrc_open:<rtspsrc0> can't get sdp
0:00:00.143195914 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:5585:gst_rtspsrc_loop_send_cmd:<rtspsrc0> cancel previous request LOOP
0:00:00.143251749 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd:<rtspsrc0> connection flush busy WAIT
0:00:00.143271021 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush:<rtspsrc0> set flushing 1
0:00:00.143300449 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:8346:gst_rtspsrc_thread:<rtspsrc0> got command CLOSE
0:00:00.143321179 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush:<rtspsrc0> set flushing 0
0:00:00.143344356 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:7569:gst_rtspsrc_close:<rtspsrc0> TEARDOWN...
0:00:00.143362795 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:7574:gst_rtspsrc_close:<rtspsrc0> not ready, doing cleanup
0:00:00.143379462 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:7637:gst_rtspsrc_close:<rtspsrc0> closing connection...
0:00:00.143396077 32612 0x558a3461e0 DEBUG rtspsrc gstrtspsrc.c:2058:gst_rtspsrc_cleanup:<rtspsrc0> cleanup
Setting pipeline to NULL ...
0:00:00.143477382 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:8422:gst_rtspsrc_stop:<rtspsrc0> stopping
0:00:00.143507487 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:5567:gst_rtspsrc_loop_send_cmd:<rtspsrc0> sending cmd WAIT
0:00:00.143527852 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:5593:gst_rtspsrc_loop_send_cmd:<rtspsrc0> connection flush busy WAIT
0:00:00.143546446 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:4748:gst_rtspsrc_connection_flush:<rtspsrc0> set flushing 1
0:00:00.143600927 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:7569:gst_rtspsrc_close:<rtspsrc0> TEARDOWN...
0:00:00.143622334 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:7574:gst_rtspsrc_close:<rtspsrc0> not ready, doing cleanup
0:00:00.143640199 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:7637:gst_rtspsrc_close:<rtspsrc0> closing connection...
0:00:00.143657596 32612 0x558a42ba10 DEBUG rtspsrc gstrtspsrc.c:2058:gst_rtspsrc_cleanup:<rtspsrc0> cleanup
Freeing pipeline ...
