Currently, ParaView connector exports USDA format.
Would it be possible to have an option to switch to .usdc format?
The fact that simulation data has a large file size and is in a text file format affects the loading speed, especially for real-time visualization of simulation data, which requires fast data loading, which means that real-time performance is lost for analysis results with large amounts of data.
Hello takashi1,
A developer has reviewed your inquiry and has the following response:
“With the public version of the connector, it does give Usdc output when writing to an Omniverse server. So you can just write to a local Omniverse server instead of the filesystem.”
I hope this solution is helpful.
