I am trying to add the support for V4L2_PIX_FMT_SBGGR12P in camera_common.c in camera_common_color_fmts.
I am seeing that there I can follow below post for adding support for V4L2_PIX_FMT_SBGGR12 as below (seeing this post)
+ MEDIA_BUS_FMT_SBGGR12_1X12,
+ V4L2_COLORSPACE_SRGB,
+ V4L2_PIX_FMT_SBGGR12,
For V4L2_PIX_FMT_SBGGR12, I can find entries in v4l2-common.c and
{ .format = V4L2_PIX_FMT_SBGGR12, .pixel_enc = V4L2_PIXEL_ENC_BAYER, .mem_planes = 1, .comp_planes = 1, .bpp = { 2, 0, 0, 0 }, .hdiv = 1, .vdiv = 1 },
tegra/camera/sensor_common.c
(If i use pixel_t)
else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
*format = V4L2_PIX_FMT_SBGGR12;
Also for MEDIA_BUS_FMT_SBGGR12_1X12 its defined in include/uapi/linux/media-bus-format.h
But, when I try to add support for V4L2_PIX_FMT_SBGGR12P I cannot find and definition in the code v4l2-common.c and sensor_common.c (for bayer_bggr12 for packed). Also the bigger problem is I see no define for MEDIA_BUS_FMT_SBGGR12_1X12 (for packed format) in uapi/linux/media-bus-format.h.
So could any one know how to add support for BGGR12P and if the support is available in upstream?
