Hi all,
I have installed suse10.0 in my pc. I am trying to compile terrain and it complains about the library lx11.a in /usr/local/ncarg/lib. I donot have the library in that directory. By the way i downloaded the PGI compiled binaries for the NCAR graphics from their web site.
Thanks in advance for any help.
Krishna
Hi Krishna,
I’m assuming that your using the 64-bit version of SuSE 10? If so, change the LOCAL_LIBRARIES variable in “linux” section of the Terrrain Makefile to point to the 64-bit versions of the X11, system, and PGI libraries. I also changed “-lf2c” to “-g77libs”.
Change:
grep Linux .tmpfile ; \
if [ $$? = 0 ]; then echo "Compiling for Linux" ; \
( $(CD) src ; $(MAKE) all \
"RM = $(RM)" "RM_LIST = $(RM_LIST)" \
"LN = $(LN)" "MACH = SGI" \
"MAKE = $(MAKE)" "CPP = /lib/cpp" \
"CPPFLAGS = -I. -C -traditional -D$(NCARGRAPHICS) -DRECLENBYTE" \
"FC = pgf90" "FCFLAGS = -I. -byteswapio"\
"LDOPTIONS = " "CFLAGS = -I." \
"LOCAL_LIBRARIES= -L$(NCARG_ROOT)/lib -L/usr/X11R6/lib
-lncarg -lncarg_gks -lncarg_c -lX11 -L$(PGI)/linux86/lib -L/usr/lib -lf2c" ) ; \
To:
"LOCAL_LIBRARIES= -L$(NCARG_ROOT)/lib -L/usr/X11R6/lib64
-lncarg -lncarg_gks -lncarg_c -lX11 -L$(PGI)/linux86-64/lib -L/usr/lib64 -lg77libs" ) ; \
Hope this helps,
Mat
