SUSE 10.4 64 bit GTX 680M graphics help and driver needed
We have a system the currently runs on old workstations that we are trying to bring up on new high end Intel I7 laptops with NVIDIA GeForce GTX 680M graphics. Unfortunately the systems runs under 64 bit SUSE Linux 10.4 that does not support the 680M by default. The NVIDIA website does have a new SUSE driver but it is only lists SUSE versions newer then version 11.
The system does not have net access at the moment either so I can not easily at least go out and just pull in new things.
Does anyone know if there is a driver I can get to work in 10.4 that will support the 680M? If such a driver does exist for such an old SUSE version any suggestions on the best way to install and get it working would also be helpful because I will probably have to do this the hard way.
Any reason not to install the normal .RUN driver?
I see what I am guessing you mean by the normal run here.
http://www.nvidia.com/object/linux-display-amd64-310.19-driver.html
The instructions for that file only appear to cover SUSE going back to 11.3. If people think that is my best option I can give it a try but was hoping someone might have some experience with 10.4. I do not need any new features so if there is an older version that is known to work with 10.4 it would probably be a better fir for me.
OK I did the install of the new driver with no reported errors but things are still not working correctly when I try to go to run level 5. Below is my Xorg.O.log with the errors. I am not at all sure what the real issue is. My first thought was that it was trying to use the onboard graphics instead of the invidia card but my attempts to change the oxorg.conf file have resulted in either making things worse or no change. If anyone has any suggestions on what needs to be done to oxorg.conf or other ideas it would be greatly appreciated.
X Window System Version 6.9.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 6.9
Build Operating System: SuSE Linux [ELF] SuSE
Current Operating System: Linux linux-osi1 2.6.16.60-0.85.1-smp #1 SMP Thu Mar 17 11:45:06 UTC 2011 x86_64
Build Date: 17 February 2011
Before reporting problems, check http://wiki.X.Org
to make sure that you have the latest version.
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Wed Dec 5 07:06:16 2012
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Layout0”
) |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
) | |–>Device “Device0”
() |–>Input Device “Keyboard0”
) |–>Input Device “Mouse0”
(**) FontPath set to “/usr/X11R6/lib/X11/fonts/local/,/usr/X11R6/lib/X11/fonts/misc/:unscaled,/usr/X11R6/lib/X11/fonts/100dpi/:unscaled,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/CID/,/usr/X11R6/lib/X11/fonts/100dpi/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/truetype/”
(==) RgbPath set to “/usr/X11R6/lib/X11/rgb”
(==) ModulePath set to “/usr/X11R6/lib64/modules/updates,/usr/X11R6/lib64/modules”
ACPI: OSPMOpen called
ACPI: Opening device
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/X11R6/lib64/modules/fonts/libbitmap.so
(II) Module bitmap: vendor=“X.Org Foundation”
compiled for 6.9.0, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/X11R6/lib64/modules/libpcidata.so
(II) Module pcidata: vendor=“X.Org Foundation”
ABI class: X.Org Video Driver, version 0.8
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,0154 card 1558,7102 rev 09 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,0151 card 0000,0000 rev 09 class 06,04,00 hdr 81
(II) PCI: 00:02:0: chip 8086,0166 card 1558,7102 rev 09 class 03,00,00 hdr 00
(II) PCI: 00:14:0: chip 8086,1e31 card 1558,7102 rev 04 class 0c,03,30 hdr 00
(II) PCI: 00:16:0: chip 8086,1e3a card 1558,7102 rev 04 class 07,80,00 hdr 80
(II) PCI: 00:1a:0: chip 8086,1e2d card 1558,7102 rev 04 class 0c,03,20 hdr 00
(II) PCI: 00:1b:0: chip 8086,1e20 card 1558,7102 rev 04 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,1e10 card 0000,0000 rev c4 class 06,04,00 hdr 81
(II) PCI: 00:1c:1: chip 8086,1e12 card 0000,0000 rev c4 class 06,04,00 hdr 81
(II) PCI: 00:1c:2: chip 8086,1e14 card 0000,0000 rev c4 class 06,04,00 hdr 81
(II) PCI: 00:1c:3: chip 8086,1e16 card 0000,0000 rev c4 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,1e26 card 1558,7102 rev 04 class 0c,03,20 hdr 00
(II) PCI: 00:1f:0: chip 8086,1e57 card 1558,7102 rev 04 class 06,01,00 hdr 80
(II) PCI: 00:1f:2: chip 8086,1e03 card 1558,7102 rev 04 class 01,06,01 hdr 00
(II) PCI: 00:1f:3: chip 8086,1e22 card 1558,7102 rev 04 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 10de,11a0 card 1558,7102 rev a1 class 03,00,00 hdr 00
(II) PCI: 03:00:0: chip 10ec,5289 card 1558,7102 rev 01 class ff,00,00 hdr 80
(II) PCI: 03:00:2: chip 10ec,8168 card 1558,7102 rev 0a class 02,00,00 hdr 80
(II) PCI: 04:00:0: chip 8086,088e card 8086,4060 rev 24 class 02,80,00 hdr 00
(II) PCI: 05:00:0: chip 197b,2380 card 1558,7102 rev 30 class 0c,00,10 hdr 80
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x100000000) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0010 (VGA_EN is cleared)
(II) Bus 1 I/O range:
[0] -1 0 0x0000e000 - 0x0000efff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf6000000 - 0xf70fffff (0x1100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xf1ffffff (0x12000000) MX[B]
(II) Bus 2: bridge is at (0:28:0), (0,2,2), BCTRL: 0x0010 (VGA_EN is cleared)
(II) Bus 3: bridge is at (0:28:1), (0,3,3), BCTRL: 0x0010 (VGA_EN is cleared)
(II) Bus 3 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 3 non-prefetchable memory range:
[0] -1 0 0xf7a00000 - 0xf7afffff (0x100000) MX[B]
(II) Bus 3 prefetchable memory range:
[0] -1 0 0xf2100000 - 0xf21fffff (0x100000) MX[B]
(II) Bus 4: bridge is at (0:28:2), (0,4,4), BCTRL: 0x0010 (VGA_EN is cleared)
(II) Bus 4 non-prefetchable memory range:
[0] -1 0 0xf7900000 - 0xf79fffff (0x100000) MX[B]
(II) Bus 5: bridge is at (0:28:3), (0,5,5), BCTRL: 0x0010 (VGA_EN is cleared)
(II) Bus 5 non-prefetchable memory range:
[0] -1 0 0xf7800000 - 0xf78fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(0:2:0) Intel Corporation unknown chipset (0x0166) rev 9, Mem @ 0xf7400000/22, 0xd0000000/28, I/O @ 0xf000/6
(–) PCI: (1:0:0) nVidia Corporation unknown chipset (0x11a0) rev 161, Mem @ 0xf6000000/24, 0xe0000000/28, 0xf0000000/25, I/O @ 0xe000/7, BIOS @ 0xf7000000/19
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MXB
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xf7800000 - 0xf78000f0 (0xf1) MX[B]
[1] -1 0 0xf7801000 - 0xf78017f0 (0x7f1) MX[B]
[2] -1 0 0xf7900000 - 0xf7901ff0 (0x1ff1) MX[B]
[3] -1 0 0xf2100000 - 0xf2103ff0 (0x3ff1) MX[B]
[4] -1 0 0xf2104000 - 0xf2104ff0 (0xff1) MX[B]
[5] -1 0 0xf7a00000 - 0xf7a0fff0 (0xfff1) MX[B]
[6] -1 0 0xf7b15000 - 0xf7b150f0 (0xf1) MX[B]
[7] -1 0 0xf7b16000 - 0xf7b167f0 (0x7f1) MX[B]
[8] -1 0 0xf7b17000 - 0xf7b173f0 (0x3f1) MX[B]
[9] -1 0 0xf7b10000 - 0xf7b13ff0 (0x3ff1) MX[B]
[10] -1 0 0xf7b18000 - 0xf7b183f0 (0x3f1) MX[B]
[11] -1 0 0xf7b1b000 - 0xf7b1b000 (0x1) MX[B]
[12] -1 0 0xf7b00000 - 0xf7b0fff0 (0xfff1) MX[B]
[13] -1 0 0xf7000000 - 0xf707fff0 (0x7fff1) MXB
[14] -1 0 0xf0000000 - 0xf1fffff0 (0x1fffff1) MXB
[15] -1 0 0xe0000000 - 0xeffffff0 (0xffffff1) MXB
[16] -1 0 0xf6000000 - 0xf6fffff0 (0xfffff1) MXB
[17] -1 0 0xd0000000 - 0xdffffff0 (0xffffff1) MXB
[18] -1 0 0xf7400000 - 0xf77ffff0 (0x3ffff1) MXB
[19] -1 0 0x0000d000 - 0x0000d0f0 (0xf1) IX[B]
[20] -1 0 0x0000f040 - 0x0000f050 (0x11) IX[B]
[21] -1 0 0x0000f060 - 0x0000f070 (0x11) IX[B]
[22] -1 0 0x0000f080 - 0x0000f080 (0x1) IX[B]
[23] -1 0 0x0000f090 - 0x0000f090 (0x1) IX[B]
[24] -1 0 0x0000f0a0 - 0x0000f0a0 (0x1) IX[B]
[25] -1 0 0x0000f0b0 - 0x0000f0b0 (0x1) IX[B]
[26] -1 0 0x0000e000 - 0x0000e070 (0x71) IXB
[27] -1 0 0x0000f000 - 0x0000f030 (0x31) IXB
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xf7800000 - 0xf78000f0 (0xf1) MX[B]
[6] -1 0 0xf7801000 - 0xf78017f0 (0x7f1) MX[B]
[7] -1 0 0xf7900000 - 0xf7901ff0 (0x1ff1) MX[B]
[8] -1 0 0xf2100000 - 0xf2103ff0 (0x3ff1) MX[B]
[9] -1 0 0xf2104000 - 0xf2104ff0 (0xff1) MX[B]
[10] -1 0 0xf7a00000 - 0xf7a0fff0 (0xfff1) MX[B]
[11] -1 0 0xf7b15000 - 0xf7b150f0 (0xf1) MX[B]
[12] -1 0 0xf7b16000 - 0xf7b167f0 (0x7f1) MX[B]
[13] -1 0 0xf7b17000 - 0xf7b173f0 (0x3f1) MX[B]
[14] -1 0 0xf7b10000 - 0xf7b13ff0 (0x3ff1) MX[B]
[15] -1 0 0xf7b18000 - 0xf7b183f0 (0x3f1) MX[B]
[16] -1 0 0xf7b1b000 - 0xf7b1b000 (0x1) MX[B]
[17] -1 0 0xf7b00000 - 0xf7b0fff0 (0xfff1) MX[B]
[18] -1 0 0xf7000000 - 0xf707fff0 (0x7fff1) MXB
[19] -1 0 0xf0000000 - 0xf1fffff0 (0x1fffff1) MXB
[20] -1 0 0xe0000000 - 0xeffffff0 (0xffffff1) MXB
[21] -1 0 0xf6000000 - 0xf6fffff0 (0xfffff1) MXB
[22] -1 0 0xd0000000 - 0xdffffff0 (0xffffff1) MXB
[23] -1 0 0xf7400000 - 0xf77ffff0 (0x3ffff1) MXB
[24] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[25] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[26] -1 0 0x0000d000 - 0x0000d0f0 (0xf1) IX[B]
[27] -1 0 0x0000f040 - 0x0000f050 (0x11) IX[B]
[28] -1 0 0x0000f060 - 0x0000f070 (0x11) IX[B]
[29] -1 0 0x0000f080 - 0x0000f080 (0x1) IX[B]
[30] -1 0 0x0000f090 - 0x0000f090 (0x1) IX[B]
[31] -1 0 0x0000f0a0 - 0x0000f0a0 (0x1) IX[B]
[32] -1 0 0x0000f0b0 - 0x0000f0b0 (0x1) IX[B]
[33] -1 0 0x0000e000 - 0x0000e070 (0x71) IXB
[34] -1 0 0x0000f000 - 0x0000f030 (0x31) IXB
(II) LoadModule: “dbe”
(II) Loading /usr/X11R6/lib64/modules/extensions/libdbe.so
(II) Module dbe: vendor=“X.Org Foundation”
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “extmod”
(II) Loading /usr/X11R6/lib64/modules/extensions/libextmod.so
(II) Module extmod: vendor=“X.Org Foundation”
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “type1”
(II) Loading /usr/X11R6/lib64/modules/fonts/libtype1.so
(II) Module type1: vendor=“X.Org Foundation”
compiled for 6.9.0, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: “freetype”
(II) Loading /usr/X11R6/lib64/modules/fonts/libfreetype.so
(II) Module freetype: vendor=“X.Org Foundation & the After X-TT Project”
compiled for 6.9.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/X11R6/lib64/modules/extensions/libglx.so
(II) Module glx: vendor=“NVIDIA Corporation”
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 310.19 Thu Nov 8 01:12:43 PST 2012
(II) Loading extension GLX
(II) LoadModule: “nvidia”
(II) Loading /usr/X11R6/lib64/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor=“NVIDIA Corporation”
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/X11R6/lib64/modules/input/kbd_drv.so
(II) Module kbd: vendor=“X.Org Foundation”
compiled for 6.9.0, module version = 1.0.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: “mouse”
(II) Loading /usr/X11R6/lib64/modules/input/mouse_drv.so
(II) Module mouse: vendor=“X.Org Foundation”
compiled for 6.9.0, module version = 1.0.3
(II) NVIDIA dlloader X Driver 310.19 Thu Nov 8 00:53:33 PST 2012
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 00:02:0
(WW) NVIDIA: No matching Device section for instance (BusID PCI:1:0:0) found
(EE) No devices detected.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.X.Org
for help.
Please also check the log file at “/var/log/Xorg.0.log” for additional information.
ACPI: Closing device
You are using an Optimus-Setup, so you can’t easy use the nvidia driver.
Thanks. I had been unaware of the Optimus issues. Not sure what we will end up doing but at least I understand the issue now.
You can use bumblebee.
